how big
gforces
05-28-2001, 09:45 PM
hey anybody know how big of a rim i can put on a p11 i really like the dazz matiz and wonder if i can get 19s on my G can any one tell me please!:confused:
primera man
05-28-2001, 09:55 PM
Check out b-bOOgie's reply in
"Finally...pics of my car" (page2) in the "GENERAL"
He has put all the sizes for rims/tyres.
Cheers.
b-b00gie
05-28-2001, 10:37 PM
lol.. primera man.. thats not jason.. its.. its... an imposter! lol
anyway...
gforces.... i'm thinking about going to 19's.. i have 18's now..
you should be able to fit a 19x7.5 no problem. there arent that many made in that size but there are a few...
the only fitment problem is that the smallest tire you can get, and the one you should use for that size wheel is a 225/35/19.. but the actual outside diameter of the wheel is slightly larger than the stock wheels... about an inch overall.. which means 1/2 inch on each side...
so your 2 concerns are.. 1) the car will now ride 1/2" higher than with other size wheels.. 2) the wheel will be 1/2" closer to the wheel well gaurds so you may have some rubbing during big bumps.. you may want to remove them?
again.. i HAVE NOT tried this setup... i suggest you test fit things first if possible before commiting to buying 19" wheels and tires..
primera man
05-28-2001, 10:41 PM
LOL.... Yeah i just clicked to that one to....out came the edit reply ...lol
b-b00gie
05-28-2001, 10:47 PM
btw gforces...
if you do put 19's (assuming they fit) you should know that since the outside diameter of the tire is larger your MPH readings, etc will be off....
if you go with 18's get a 225/35/18 tire size as it will give you the same outside diameter as the stock wheels...
gforces
05-29-2001, 12:40 AM
Thanks guys! but i just found out there is another guy named g-forces on this board and i am gforces oops now lets see how i could change this cause i dont want to be an imposter:rolleyes:
ales
05-29-2001, 12:54 AM
Yeah, you do that. that guy is one of the moderators of this forum and the owner of G20.net. Hehe. Run while you can
:)<-me
:devil:<--Jason
primera man
05-29-2001, 01:04 AM
LOL.....I WAS CAUGHT OUT BY IT !!!!
Twiggy
05-29-2001, 02:15 AM
Ok now im back instead of "gfroces" im "Twiggy":p
primera man
05-29-2001, 08:08 AM
Jason will be a lot happier now !!!!
Nismoboy1
05-29-2001, 09:53 AM
you should be able to fit 19's...make sure it's no bigger than 19x8" and your tires, 225/35 and your offset is between +42mm and +48mm, and you should be fine...those Dazz Matiz's are probably the next set of wheels i'd get if was gonna get some new wheels, either those or some dronell's :D
blkghst3
06-06-2001, 02:11 AM
hey guys there is new 19 inch tire out now. it is produce by pirelli. the dimens are 215/35/19 pzeros. the price is about 250US dollars per tire.:eek: :D
hooktup99g20
06-06-2001, 02:29 AM
i probably cant but can i fit 18x10'son the back of my 99 g20??:confused:
blkghst3
06-06-2001, 02:32 AM
noooooooo! impossible
hooktup99g20
06-06-2001, 02:34 AM
what about 18x8.5??:confused:
b-b00gie
06-06-2001, 07:21 AM
an 18x8.5 will fit on a stock G20 suspension (p11). its the widest you can go (not sure of the offset), however on a lowered car i'm not sure if it will rub on anything or not, i know on the front it would definately rub on a lowered car because of the upper link arm.
