Box truck turbo?Tims_240 08-24-2004, 11:27 PM i live beside a person with a box truck that says turbo intercooled the box truck is like an NPR or something like that wtf? does it have a turbo on it? what kind would you think it would be? i know its kind of a dumbass question but im thinkin since the truck just sits there then his turbo might be able to be put to good use.. lol SR20DETpower 08-25-2004, 08:11 AM its probably something equivelant to a T-25 or T3.... like 99% of stock turbos are on import engines. it probably is turbocharged..wouldn't doubt it Chuki_breath 08-26-2004, 12:38 PM yea alot of diesel engines in trucks are turbo. Tims_240 08-26-2004, 04:40 PM you think it would work on a '93, 240? winstonusmc 08-26-2004, 04:55 PM If this truck is a diesel, the turbo is probably too large for your aplication. A box truck has a larger displacement motor and probably has a turbo that wasnt designed for it. You have to find out the model and specs of the turbo, and then compare it to similar setups I.E. if has a T3 with an AR in the turbine matching a similar setup that someone else is running, thats OK. A turbo has to be carefully matched to an engine, if not, you may have a lot of "lag" or even a loss in power. This is an advantage of having a turbo kit or having an engine that already has a turbo. My engine has many different turbos I can bolt to it, all have been tried and proven, all I have to do is pick one for my needs. I have tried to use budget turbos that may work on a car, but remember, a turbo is part of a system. May different variables that make up this system that engineers have already figured and proven. When you pull from one system and try to add it to a whole new application, you need to do similar research. Learn how to read a turbo map, it helps. Automotive Network, Inc., Copyright ©2012
