'94 ZJ Drum to Disc Conversion?ShadMan 08-24-2004, 11:26 PM Has anyone converted their rear drums to disc brakes? I am considering doing it. Can someone run through the process? Is there anything special needed, or does it all bolt right up. Also, what parts would I need to buy? Obviously the rotors, pads, and calipers...anything else? Can I just use the parts that came on the 94s that had the discs as an option and will they bolt up to the backing plate I currently have? Also, probably a stupid question, but does the '94 JGC Laredo (ZJ) use the Dana 35 rear end? ByronP 08-25-2004, 12:55 AM The axle is probably a D35. If you check the little tag attached to the axle near on the differential cover it will tell you. They may have offered a D44 but I'm not sure what years (+95 I think). The tag will tell you the model. Automotive Network, Inc., Copyright ©2012
