NA header =\
KenOhki2112
08-24-2004, 05:29 PM
Header cracked a few weeks after my new exaust was installed, the guy at the shop wants to put a pacesetter on it $260 parts $60 labor.. I've heard some complaints about the pacesetter, any one have a recomendation for a header? Hotshot maybe? Who else makes a nice header for my car? CA Carb sticker required =(((
(1990' KA24E)
nissanfanatic
08-24-2004, 05:41 PM
$260 for a pacesetter? He must be ripping you off. I paid $180 for mine (KA24DE) with second day air from Summit Racing. Or do you mean $260 including labor? $260 including labor isn't bad, but putting a header on isn't that hard. Three hours of work at the most. EGR is a pain, but that's it.
nissanfanatic
08-24-2004, 05:44 PM
Here I found the catalog.
Part #-PSM-70-1286 for 1989-91 240sx
2.4L SOHC...............$152.99
Phone number is 1-800-962-9094
www.summitracing.com
mrflip69
08-24-2004, 07:58 PM
The only legal exhaust header for the 240sx is from Greddy for the S14 (95-98)
http://www.arb.ca.gov/msprog/aftermkt/devices/amquery.php
Search under Exhaust System / Modification
KenOhki2112
08-24-2004, 08:24 PM
I dunno about that.. I saw the ARB certificate for the pacesetter..
Any more, if this place put an illegal header on my car, being well established they would be responsible for a huge fine. And they know about that, so I'm pretty sure they wouldn't sell me an illegal part.
SR20DETpower
08-24-2004, 08:33 PM
BEFORE you spend money on a header, find out why your exhaust manifold cracked because it will happen to an aftermarket header easier.
you probably have an exhaust hangar problem or the exhaust is resting on something.... or your exhaust(custom made perhaps..if so read on) is not made perfectly and not straight onto the manifold, with the exhaust piping bolted down or something it might stress the header if they don't line up perfectly
:2cents:
KenOhki2112
08-24-2004, 08:57 PM
The pipe is cracked north of the cat where the two header pipes weld together (formerly under the heatshield), it was mostlikely cracked before the exaust was redone. When we removed the heat sheild we found several bits of debris, including one of the bolts that was suposed to be bolting the header in up top -_-.
Actualy that's not what we think the rattle is coming from though, at the bottom of the header where it bolts on to the pipe, one of the washers has rusted off (the whole pipe looks really bad rust wise). when I hit the pipe the noise was coming from that spot, not the crack. I watched them build the pipe in the first place, they did a very good job so I don't think that was the cause, I also remember hearing that horrible rattle well before I redid the exaust.
SR20DETpower
08-24-2004, 09:05 PM
are there any heat shields on your exhaust or cat? sometimes, well often, the weilds on those break and they can make a buzzing or rattling sound like a MOFO specially at idle or just moveing at like 1-5mph from a stop.
Chuki_breath
08-24-2004, 09:45 PM
yes those heatsheilds are a BIIIITCH, whine more than my girl friend....fortunatley i can take heat shields off and throw them in the trash, as for the girl.....dont want jail time but i just tell her "you keep runnin your mouth im gonna stick my dick in it" she shuts up quick.
KenOhki2112
08-25-2004, 12:53 AM
I removed the heat sheild next to the cat, not the one up on top though (good idea to leave that on so when you go for smog it looks stock).
The heat sheild was causing some of the rattle, namely the bolt I found loose inside of it =(
Even with it off though, the main rattling is still there, has to be the header.
SR20DETpower
08-25-2004, 08:05 AM
maybe the header was always cracked and the souce of that noise?
