Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > MG > Nonspecific
Old 08-24-2004, 03:16 PM   #1
bmwwxman
bmwwxman Normal reputation
wrenches on a TD
A friend called me asking a question I couldn't answer. He's changing out the thermostat on a TD and can't find a wrench (spanner) to fit the mounting bolts. I can't remember what sizes these bolt heads are. I didn't think they were Whitworth, but he said none of his standard metric wrenches fit. Although this is a USA car, I wouldn't think these bolts would be SAE. Anyone know???
Cheers!!
Jimindodgecity
bmwwxman is offline   Reply With Quote
Old 04-20-2005, 11:16 AM   #2
ClearHooter
ClearHooter Normal reputation
Re: wrenches on a TD
They probably are Whitworth. Old Goerge was an inventor.....just not a bright one. He also is credited to the wire wheels splines on British cars. Boy... There was a brain fart.
ClearHooter is offline   Reply With Quote
Old 04-20-2005, 12:45 PM   #3
bmwwxman
Re: Re: wrenches on a TD
We figured it out. They are, in fact, SAE - I forget the size as it was last year. My old TC and now my 68 Midget have the splines on the axel stubs. I've never had a problem with them. What do you know that I need to know??! :-)
Old 04-20-2005, 01:30 PM   #4
ClearHooter
It's not so much the size of the hex-head as the threads that seperates Withworth from everything else. Though there probably are some things that just don't cross over. Like there's no match for a 10mm in metric as an example. Most of the odd ball Withworth stuff on my 100/4 can be taken off with SAE though it might be something like a 1 13/16 that has to fit it.
Wire wheels? Love / hate relationships. By the nature of physics when the brake is applied the center of the wheel has a tendency to stop before the out side of the wheel. Over time this sets up a wear pattern on a wheel, even ones that are taken good care of. Most haven't. Always thighten the knock-offs securely. Keep them greased. Every 2000 miles or so, or 1000 on recomended chassis greasing R&R them. This helps insure they don't stick on the hubs. I don't recommend rotating wheels as this also rotates wear patterns from one wheel to another. There is no good way to get around this as a tire shop unfamiliar with wires can screw them up just refitting tires to the wires. I love the way wires look; but if I get my way I'd rather have solid wheels. This of course isn't easy on an MG as a change over requires a swap of hubs and complete rear end change. A tell tail sign of wire wheel fatigue is when you apply the brakes and you hear a POP! You know that the splines are starting to wear. If you check them and see that they are not straight it will be just a matter of time before you'll lose one. If you've got a set of wires that are good, you're lucky. Keep 'em true, greased and maintained and they'll probably serve you long.
Old 04-20-2005, 01:55 PM   #5
bmwwxman
Wire Wheels & splines
I guess I'm kinda anal about wire wheels. It was always obvious to me that the spline area on the axle hubs was a prime candidate for wear if not properly taken care of. I have always greased my hubs at about 1K mile intervals and frequently check them. For the same reason, I keep the hub nuts nice and tight. In fact, the '68 Midget has the octagonal hub nuts which I dislike. I've bent the hub nut wrench (Moss Motors) pretty badly trying to tighten and loosen them. I much prefer the winged knock-offs and alloy hammer and will be changing to those on the Midget soon.
Old 04-20-2005, 03:02 PM   #6
ClearHooter
I've always thought four big spline would have been a better idea than a 100 little ones. Probably wouldn't make any difference. Forces of inertia would act the same on both. It just seems they would be less likely to ride over oneanother.
Bookmarks
Google
Web AF
