ca18det or sr20det???iNmotioN 08-24-2004, 01:48 PM i was just wondering if a ca18det is worth buying, i heard it comes with an iron block. which one is better to build??? winstonusmc 08-24-2004, 02:14 PM IT all depends on certain variables. One would be if you have a 89-90 s13, the wiring is the old style and the swap will work with your power steering and tach. The CA is limited in that the electronics are older and you have a little less displacement. With some of the same mods as an SR you could be making SR power, but I have heard the max reliable power is less. The best advantage to the CA is parts interchangeablity with use motors and cost. The 88 or 89 Pulsar NX is a CA18de with the same DFI as the CA18det has, Direct Fire Ignition with one coil per spark plug. I have rode in a CA18DET powered silvia, it was fast but it was modified, turbo, FMIC, and some other unnoticed things. I like my SR though, a little pricey but a stout motor. It has an aluminum block but it has been known to hold 550hp on stock internals. I like it because of the large aftermarket for it, and there are plenty of people modifying them so I can copy their setups. winstonusmc 08-24-2004, 02:17 PM I see your pic is the S14, if that is your car, I would go with the SR20DET, s13 or s14. The electronics and power steering will be compatable. pnoiSR20 08-24-2004, 11:49 PM Which car requires less fabrication on a Datsun 510? racer98 08-28-2004, 02:15 PM Which car requires less fabrication on a Datsun 510? what do you mean > u want too put 1 in it ???? sidewayzS13 08-28-2004, 07:23 PM this topic has been covered many times i beleive search it sRscooby 08-28-2004, 07:27 PM i don't think any car would fit in an 510 :biggrin: well, unless you get a mini cooper or something, the old ones pnoiSR20 08-28-2004, 11:13 PM My bad....which motor requires less fabrication? A ca18det or SR20DET on a 510? x~Underoath~x 08-28-2004, 11:33 PM Dont get a CA, youll make prices go up. Everyone, stop buying CAs and start buying more and more SRs. Then we can both be cool. I willing to share my coolness here. Ace$nyper 08-28-2004, 11:35 PM Dont get a CA, youll make prices go up. Everyone, stop buying CAs and start buying more and more SRs. Then we can both be cool. I willing to share my coolness here. lmfao and for our mod whos shown back up ROLF! SR for life yo! :evillol: Automotive Network, Inc., Copyright ©2012
