2002 Door lock prob...
nheck
08-23-2004, 09:06 AM
It appears that all of the door locks, windows, and mirrors have quit working from both the driver-side controls, and from their own sides. Only the driver and rear driver-side windows work, and only the driver side door lock works. The liftgate doesn't work at all, what a pain that is to manually unlock! I couldn't find a fuse for them listed in the book, I thought there would be one. Does anyone have any suggestions before I have to take it to the dealer which I'm sure will cost a small fortune!! Thanks so much!!
Myrtle Beach
08-23-2004, 10:25 AM
You need to disconnect the battery cables and then hook them back up again. Have you done any electrical work around the time the problem occurred?? Anyway, disconnecting the battery will reset the computers and fix your problem. Mine did the same exact thing. Let me know if it works.
nheck
08-23-2004, 10:37 AM
Thanks! I'll try that as soon as I get home and let ya know!
xj31
08-23-2004, 07:40 PM
if what youre saying is that the passenger side windows and locks are completely inop but the drivers side works you might have a bad passenger door module.thats what they call the switches in the frt doors.if thats what it ends up being you will have to reprogram your keyless entry because the reciever for that is part of the module.hopefully Myrtle Beach is right because thats a lot cheaper and i have seen electronic modules that seem to be dead start working again after just being disconnected and reconnected
nheck
08-25-2004, 09:19 AM
I'm sorry to say that disconnecting the battery didn't work! I guess I'm going to have to bite the bullet and take it into the shop.....maybe it won't cost TOO much. Thanks for your help!
Myrtle Beach
08-25-2004, 09:25 AM
Sorry to hear that didn't work- Check out this thread-Maybe it will give you some other ideas-- http://www.automotiveforums.com/vbulletin/showthread.php?t=231833
