wind noise
02trueblue
08-22-2004, 09:05 AM
I have recently purchased by first vette. I have an 02 Coupe with the removable top. I have found that there is a small gap on the driver's side window between the glass and the weatherstripping creating some noise while driving. Is this adjustable? Can it be fixed?
vettemaan
08-22-2004, 08:40 PM
check www.corvetteforum.com
2octops
09-05-2004, 02:05 AM
Door windows can be adjusted forward, backwards, up, down, and tilted in and out. Remove door panel and locate the adjusting studs with locknuts around them. There should also be index marks on inner door skin around these adjusters. Cann't remember which does what, but only move 1/4 turn at a time adn close door and inspect. A lil goes a LONG way on these. Window should lightly press against weatherstrip all the way around. You can check the adjustment by closing the door with a dollar bill between the window and rubber. If adjusted correctly, the window whould hold the dollar in place and require a light tugging to remove it. If it falls out or feels like you gonna rip it from pulling just adjust another 1/4 turn. Also only make one adjustment at a time.
