trouble on cold start/ intermittent stallingchevyman14 08-20-2004, 09:39 PM 1996 Jimmy 4.3 L CSEFI Trouble starting on cold starts. Ignition is OK. Fuel Line pressure OK. Seems to run lean. Very lean on cold starts. Is there an initial fuel delivery sequence that pulses the injectors? Any suggestions? Your help is very much appreciated. Jeremy-WI 08-22-2004, 08:02 AM Does the fuel pressure hold steady or does it start dropping after the pump quits. If the pressure drops after the pump quits, it could be a problem with the fuel pressure regulator Teaman3 08-30-2004, 03:56 AM What makes you think it's running lean at start up ? Automotive Network, Inc., Copyright ©2012
