manifold bushing???speedracer4u2c 08-20-2004, 06:59 PM i was leaving the house this afternoon when all of the sudden it felt like the engine was losing compression, and started making a noise like the muffler had blown a hole.... well my manifold pipe has come loose, blown a bushing? that's my question, since all that is there is the bolts and the ring and sleeve, WAS there a bushing there that needs replaced?.... there's about a 1/2" to 1" gap so that's what i'm assuming.... thanks GMTECH 08-20-2004, 08:10 PM Most likely you blew out the fiber doughnut that fit inside the exhaust pipe flange, pretty simple fix, unbolt the pipe take out the rusty sleeve that is probably still there, and install your new exhaust doughnut. Becareful when you unbolt the exhaust, the bolts get very corroded and are known to break off when trying to remove them. Get the engine good and hot first, then spray some penetrating oil on the threads and at the head of the bolt. It will smoke something fierce right off, but it will also cool the bolt while allowing the manifold to stay hot and it may make it easier to remove the flange bolts. Good Luck. jeffcoslacker 08-21-2004, 09:15 PM If the above won't loosen the bolts, blasting them with a propane torch until glowing will. Just watch what you're pointing that torch at. Plastic fuel lines melt quick. jeffcoslacker 08-21-2004, 09:17 PM Just thought about what you descibed, and there is supposed to be a spring in the position you are talking about. I think these have that. Keeps the bolt tensioned, but allows for movement and expansion. Automotive Network, Inc., Copyright ©2012
