93 Accord 3rd brake light as well as passenger brake light not workingkama 08-20-2004, 03:44 PM I check the bulbs and the fuses,,everything ok! The driver side brake light works likes a charm. The passenger light and 3 rd light do not work. My instrument panel is lit up indicating brake lamp failure. I'm thinking I have some wire problem...I can trace the wire so far,,it seems to be clean. I put a multimeter on the wire and had my girl put on the brakes and no juice out of the wire. ANYONE have any ideas. I'm trying to find some wiring diagrams for this car and try to follow that wire from front to back THANK U sdbayfisherman 08-20-2004, 07:18 PM I have the same problem. There are two Brake light warning relays and if they malfunction I think it may cause the brake light to fail. sdbayfisherman 08-20-2004, 08:25 PM Found the brake light sensor. It is located inboard of each lower lighting assembly. Unplugged it...cleaned the connecting leads. Viola! It works great now...just a plain board with a few cheap relays Automotive Network, Inc., Copyright ©2012
