Top of radiator not in a fixed positionGaffertape 08-19-2004, 11:52 AM My 1991 Accord SE's radiator mounting seems a bit odd, yet its identical to other Accords that I have seen - why is the top of the radiator not in a fixed position? It is held only loosely in place by two plastic pegs in overly wide circular openings. One can actually grasp the top of the rad and wriggle it a fair bit. Any other car I've owned has the rad bolted firmly in place. Will it do any harm to fix it into a locked position? I'm concerned that the constant shaking can't be great for the radiator. 94hondaacc 08-19-2004, 01:10 PM yeah its normal. honda radiators are held in place at the top by those two round things, but check to see if the rubber is all there. it has like a bushing around it. if not you know you can just change the two things easy. Gaffertape 08-23-2004, 07:38 AM Thanks for the tip. I think the rubber bushings were indeed a bit worn. I was able to push small rubber rings into the gap, which tightened the fitting while still giving it some freedom of movement. Automotive Network, Inc., Copyright ©2012
