turn signal question?94tegRS 02-05-2002, 01:14 AM ok, in the car i just bought, it has no front turn signals because of the body kit, I was thinking of wiring up a relay to the stock fogs and make them a blinker but i dont know if that would loook too dumb or not? also, I was thinking of just pulling out the fog light bulb and putting in a different bulb and make them a blinker, But I have thought of a way to keep stock fogs and have blinkers, I oked around on ebay and found Hyper LED's that are supposed to be really bright, well they are emant for alarms so i doubt that blinking on and off alot will hurt them also, I was thknking of getting some red ones (red undrbody lights and red emblems, etc...) and when you look at the pic, you can see those tiny little slots on the outer lower corner of the body kit, well, I was gonna just wire like 3 or 4 on each side In that hole up to the stock turn signal; system, that way id use evrything stock even the relay and everything, and have blinkers, or would you put them in the bigger outside holes? do you think they will even be bright enough. or what about just buyni regular auto bulb and just buy an old hopusing of an old car in the junk yard and mount it somnewhere behind the mesh where it isnt visible when off but they see it blinking, whuich si your favorite idea and ifg you have a different one or if you have a kit and made a custom blinker how did you do it? thanks Pineapple Devil 02-05-2002, 08:22 AM why not get some finder turn signals or mirror turn signals? both look really good. 94tegRS 02-05-2002, 11:21 AM what is a finder turn signal? fender? do you have a pic or it hybridDC2 02-05-2002, 01:14 PM i think he was talking about sidemarkers. 94tegRS 02-05-2002, 04:46 PM well, I would want a clear one which i can find, but I dont think it would look good mounted outside the bumnper and i dont think I could make it fit into it flush. ill try the behind the mesh thing i guess and then maybe the LED thing and see if it is visibla at all in thre day time. Automotive Network, Inc., Copyright ©2012
