lost locking lug nut keymanlion 08-13-2004, 08:39 AM i bought a car and the owner does not have the locking lug nut key. What can I do? timberdoodle 08-13-2004, 09:31 AM i dont think vice grips would put enough of a hold on something that tight, worth a try. Other than that cut a slot down one sid of it, not deep enough to cut the threads of course, and use a cold chisle to spread the nut apart so you can get it off. Also, whats the manf.? cant you jsut go get another one at the dealer or something? MagicRat 08-14-2004, 10:25 PM Often factory locking nuts use just one of a few key patterns. The dealer could identify the pattern and sell you a key or just remove then for you. If its aftermarket, it may be a lot of trouble. As for removal, a hammer and chisel might work, but instead of splitting the nut, try first to hit the chisel so it bits into the nut at an angle, so you might be able to knock it loose. Another trick is to try some metric or standard 12 point sockets. Locate the one that is closest to fitting over the nut but not quite. Then use a big hammer to drive the socket over the nut. Often the socket can bite into the sides of the nut just enough to get a grip, then twist the socket off. Use a good quality socket and eye protection. As a last resort, a regular nut can be welded to the lug nut so a wrench can be used. TechX 08-16-2004, 05:13 PM Go to a wonderful place like Sears and they have kits made for taking off locknuts. A skilled Tech should have no problem getting them off. MagicRat 08-16-2004, 09:33 PM Go to a wonderful place like Sears and they have kits made for taking off locknuts. Maybe we should call Sears "Thieves 'R' Us" TechX 08-17-2004, 02:06 PM Maybe we should call Sears "Thieves 'R' Us" :lol2: I worked at a Sears AC for 2 years and I must say the one I worked at had very honest techs. The salesman on the other hand...... Automotive Network, Inc., Copyright ©2012
