Seating belt light flagging & continuous beepinghienpham 08-12-2004, 11:25 PM After I turn the ignition swith on, there will be 6 long beeps to remind me to put the seating belt on. After I put the seating belt on, then there are a continuous beep with the flagging seat belt. Does any one know how to disable that beep, for now, before I can bring my car to the shop. Even I just put the ken on on position, not even start the engine it does the same. Thank you very much for all of your help. Best Regards. Hien pham boosted k20 08-12-2004, 11:41 PM How much miles does ur car have. it might be the maintenance Required reminding u to get ur maintenance done. My car was beeping just like urs 2 days ago. this is how i fixed it: look under the steering wheel colum (under the drivers side dash). Look more towards the right side. u will see a black box with a blue button. push the blue button for 5 seconds. this will reset ur maint. reqd light and get rid of that beeping. Rating 08-12-2004, 11:51 PM Hey if that doesnt work, try pulling your seat out and disconnecting the wire from your belt buckle. Thats what I did once the 4 point harness went in. Also it might just be doing that because your sensor isnt plugged in all the way, I donno just throwing ideas. Automotive Network, Inc., Copyright ©2012
