86 305 cracked heads substitute?
I have been battling the emissions on this for several years now... and come to the conclusion that I might have cracked heads. According to all the books, the 86 could have the thin casting, double passage crossover heads that are prone to cracking. So... I am going to pull them & replace. Problem is, I don't know what to replace them with. I think they are low compression 76 cc chambers.
I pulled the engine, sandblasted the block, heads, pan, valve covers etc, had the block bored and installed new pistons, rings, bearings etc. Did a 3 angle valve job on the heads, didn't see any cracks when lacquer thinner was dumped on the heads. I have valve refacing & seat cutting equipment, but I do not have a magnaflux setup and I did NOT have them magnafluxed.
I replaced the Q-Jet with a brand new Holley 80555 and re-engineered the vaccum hoses to run the emissions equipment, and I used a 1980 Vette EGR with a little mill work to fit. It runs, barely. So... with all of the emissions equipment disconnected, with only the vac advance connected (no other vac lines connected, no power brakes) and with a Accel HEI distributor (no ECM etc), and new intake gaskets, the engine runs like it still has a massive vaccum leak. Compression is good, and even. So I'm taking an educated guess that the heads are cracked internally as suggested by all the books.
I am about to buy some Edelbrock heads from Summit Racing, but I woud like to know if there are alternatives. Replacement rebuilt heads from Autoparts stores are not an option.... the chances are too great that I would end up with another set of thin casting cracked heads.
Anybody replaced the heads on their smog 305 with aftermarket heads and still pass a sniffer test? What did you use?
