My 88 Blazer Is Burning OilChevyPower 08-11-2004, 06:56 PM I have an 88 blazer with a 350. We took the head off and replaced the head gasket and once we got the engine back up to running it started smoking.It doesnt smoke that bad only a little bit when I start it up, sometimes blue smoke and sometimes black smoke.So if anybody has any ideas what I could do let me know. But im probally just going to end up doing a motor swap, just because it would probally be the best thing for the truck. MagicRat 08-11-2004, 07:37 PM Is the engine otherwise sound? Those older 350's were notorious for bad seals around the valve stems. Residual oil slowly trickeles down the intake valve stem when parked and settles aroud the intake port, causing a puff of blue upon start up. New seals usually clears this up. However, if this is something new, likely your intake manifold gasket is leaking, allowing just a bit of oily vapour to be sucked in from the lifter valley. ChevyPower 08-12-2004, 01:39 PM Yea other then that the motor is working fine, but also like a oily water comes out of the exhaust sometimes when I start it up.But it is probally the first thing you said because we replaced the intake gasket when we replaced the head gasket.Also if anyone knows a good site to buy gm engines from please let me know, Thanks Stroked it 08-12-2004, 11:30 PM rings or valves INF3RN0666 08-13-2004, 11:54 AM Oily water coming out of your exhaust is perfectly fine. I thought it was strange at first but my neighbours van is like a water hose that spurts out water 1 meter from the muffler on startup :S. There's nothing wrong with that because it's a 2003 (practically new at the time). It's just condensation but you obviously knew that. The oily part is most likely due to the residue found in the piping. I heard someone say that a new headgasket takes time to settle in an engine because oil residue fills in the spots and acts as a complete seal. Try runing it a few times and see what happens. ChevyPower 08-13-2004, 04:19 PM we changed the head gasket probally back in june but i wont worry about it until it gets worse timberdoodle 08-13-2004, 04:26 PM is it actually using oil between oil changes or just puffing smoke? Could just be your cats, mine did that even when i put in my new 350 ChevyPower 08-14-2004, 11:27 PM My dad said that it was but I really dont think it is. .It doesnt blow the puff out every time only after its been sitting, so maybe it is just the cats. But how come sometimes its blue sometimes it black? timberdoodle 08-15-2004, 06:30 PM Well there could still be some oil deposits in the old cats that havent burned off yet. Also how old are the cats? I would say before you do an engine swap, unless you really want to anyways, that you should replace the cats first and see if that does the trick? If it doesnt use any oil durning oil changes, then you probably arent burning oil. ChevyPower 08-16-2004, 03:16 PM .Well once i get caught up with everything im going to put a new exhaust on it but im doing away with the cats. .When we got the rear done we had a new exhaust on it but im not sure if he got a new cat on it or not. .The engine swap isnt coming anytime soon and i moght just sell it not sure yet Automotive Network, Inc., Copyright ©2012
