Newbie on the block!
Google
Web AF
Krystal x Method
02-04-2002, 02:57 AM
hey peeps whats, i'm new on this board tho i am a member on the Hondahookup forum. Just sayin hey!:frog:
90CRXZCSi
02-04-2002, 03:23 AM
Welcome to the forums. I hope you end up finding all the help you will need. if you need anything anytime, i or someone try to help ya.;)
spy54
02-04-2002, 03:45 AM
i referred him hes got alot of questions so i said you all were the group
crxlvr
02-04-2002, 09:01 AM
enjoy your stay here at PH/AF, we will answer any and every question you may have. Have fun.
Krystal x Method
02-05-2002, 09:59 AM
sounds good fellas, yep thanks spy, now i will ask my question for the millionth time but when i do this ima do it right, and i wanna do a swap when i get my crx, and wondering what you guys would suggest as the better swap, my original plan was a 99 civ engine with a supercharger, but is there a better engine than that, cuz i want power, and i have money, suggestions would be appreciated:smoker2:
Marc-OS
02-05-2002, 05:25 PM
Originally posted by Krystal x Method
i have money
How much money?:devil:
91zc
02-05-2002, 06:13 PM
If this is into an 88-91 civic/crx then that motor is going to be a bitch to put in because of the wiring required to run obd2. Any easier option is a jdm b16a from the civic SiR or integra xsi. This will bolt in withe the aid of a mount kit. If the motor is going into another car then let us know.:)
spy54
02-05-2002, 07:08 PM
see TOLD YA muwahahaah i was right
Krystal x Method
02-05-2002, 09:17 PM
ok spy i was just gettin a second opinion, oh yea i'll have probably 5g's plus? if i save from now till the summer which is when i wanna begin my ''project'' But i wanna ask you all this, on modacar.com there's the power packages you can buy with the cai, exhaust, headers, and a JSC, and they make one for the 90-91 crx, will it work with the sir? and whats the exact difference between the si and sir? i believe it's hp correct me if i'm wrong
Krystal x Method
02-05-2002, 09:19 PM
oh yea i kinda wanted to have a vtec in there too....i want this to be perfect :frog: :smoker2:
EightOhOne
02-05-2002, 10:12 PM
the b16a from an sir/integ xsi, is more or less the exact same engine as the engine in the 99 si, except its non OBD, has a cable tranny, and has like 10 hp less....plus its about 1000 cheaper
91zc
02-05-2002, 11:22 PM
It has the same amount of hp. The only ones that had more were the jdm 2nd gen b16s. They had a 170 hp. All US spec b16s and jdm 1st gen b16s had 160hp.:)
EightOhOne
02-06-2002, 12:05 AM
oops..let me insert my foot in my mouth:bloated:
much better
oh yeah...since you have five gs, if you did labor yourself, you could buy a turbo kit, and be boosting your b16a, and hauling some major a$$
Krystal x Method
02-07-2002, 09:32 AM
very nice i think i'll go with the jdm sir engine then, i'll have the money easy. Anyway i could get my dad to do it but i can't use up the garage bay so i think i'll have to pay for labor ya know. And i was wanting a supercharger instead, do they even make superchargers for the sir engine, because i don't know how much different they are from the crx si engine....
Worshp
02-07-2002, 07:49 PM
Correct me if i'm wrong, but isn't there a JRSC kit for the B16A3 used in the USDM Si. If so, i'm sure this would pretty much bolt straight up as most of the differences with the B16a's from gen to gen are either compression, ecu management or sensors, rather than actual engine design.
Setanta
02-08-2002, 03:26 AM
I think there may be engine bay issues though worshp, I'm not too sure. I think there's more room in a 6G bay than in a 4G - I know my SiR engine bay is cramped as all hell with the B16A plus air-con and power-steering. There's no room for a JRSC in there I don't think - unless the custom engine mounts give you more room than the Honda ones.
Persanally, if I was doing the swap I'd be turboing a B18 and forgetting about VTEC :)
Google
Web AF
