15 in tires questionviper2002 08-11-2004, 04:46 AM i have some 15 in rims, i was planning to get some low profile tires for my rims. My question is what is the difference between 205/65R-15 & 195/55R-15. Another quaestion is what would you recomend and you can also add any other info to give me a better idea what tires i should get. I would appreaciate the info . thanks oscar Grant@Tirerack 08-11-2004, 12:03 PM What make, model, and year is the vehicle? That would make things a lot easier to narrow down. goinbig 08-11-2004, 07:51 PM The 205/65-15 is 205millimeters (mm) wide and is 65mm from the rim the the outermost part of the tire (sidewall height). The other one is 195mm wide and has a sidewall height of 55mm. Hope this helps. Let us know if you have any more questions!! viper2002 08-11-2004, 08:38 PM the wheels are from an accura, cuse the center cap says accura viper2002 08-11-2004, 08:44 PM o wow! thanks for the information goingbig! thats make more sence now. I still have a question, do you if i get the same brand of tire sizes 205/65 or 205/55, will they both last the same ammount? goinbig 08-12-2004, 12:48 AM They should last the same amount of miles, give or take a few. However, They will each require a different air pressure to ensure that they will last as long as possible. Automotive Network, Inc., Copyright ©2012
