Dash covering
goldwinger
08-10-2004, 09:02 AM
Hi all I am the proud owner of a 92 Lumina Euro 3.1 I am having a problem with the padding that covers the dash, the portion to the left of the steering wheel just above the parking brake release has completely become un-glued, it goes right around to the top left of the dash. My question is. Is there a good adhesive that works well at re attaching the padding? Or am I forced to find the thousand and second use for duct tape?? Thanks
scoob8000
08-12-2004, 10:22 PM
I have a horrible time with mine delaminating.. I tried spray on headliner glue, works for a while, but comes unglued again..
Seems the foam inside the pad doesn't leave much to adhere to..
-scoob8000
goldwinger
08-13-2004, 07:20 AM
Thanks scoob8000 I was considering that spray on route. The stuff I found is made by Loctite, is that the same thing you used??
tblake
08-17-2004, 01:02 PM
I would rip it apart, take the dash apart, so you can glue it down, clamp it together, and leave it sit overnight. and I would use epoxy. Not the quick set stuff, but the stuff that takes overnight to dry completly. The stuff that comes in the double seringe sort of thing, so there is no need to guess how much to use. I used it on some weatherstripping on my older lumina, and needless to say, the stuff I glued on with epoxy lasted longer than the rest of it. This stuff is strong. Good luck.
