Removing 96 grand am se grill
dewkid_16
08-10-2004, 12:30 AM
Hi I was wondering if anyone knows how to take the grill out of a 96 grand am se. I have troubles trying to get it out. If anyone has taken their's out to paint it please help. Thanks
justin0717
08-11-2004, 11:37 PM
Pop the hood..behind it there are four things that hold it in place..push and pull in them and they should pop out...try and pry the little tabs up with a screw driver....otherwise you may break them off. i just took mine off like a week ago to paint them. its really easy..just becareful you dont break them.
dewkid_16
08-12-2004, 01:33 AM
Thanks but I have trouble mainly with the bottom ones to I want to pull up on them or down.
justin0717
08-13-2004, 09:19 AM
try and pull them straight out..get a small screwdriver back there and try and pry the little things up while pulling out.
dewkid_16
08-21-2004, 03:46 PM
I still have problems, removing it the top clips are easy to get out but the bottom ones don't come out at all. I have tried to use a screwdriver to pull up on them but that doesn't help. I have also tried to pull down on them no luck either I have tried to pull on it but that will just break it. The only thing the bottom ones do is slide around. Any ideas???
zingermans17
09-02-2004, 04:49 PM
i put a screw driver underneath the two clips on the bottom of the grill , pushed up and then pulled them out
dewkid_16
10-18-2004, 11:05 PM
So I would need to pull up on the bottom tabs at the same time and pull them out as well, right?
justin0717
10-19-2004, 09:54 PM
yea pry a screwdriver under them, and pull out. You can do one side at a time. They should just come right out. But yea becareful, i broke one of the bottom tabs when i took mine out.
