sPORTAGE RUNNING ON 2 CYLS! hELPblondeeleo 08-09-2004, 10:46 PM Sportage running on 2 cylinders can't figure it out. Replaced coils no help...Maybe Crank position sensor??? or ECM??? hELP!! jrwhited 09-18-2004, 01:45 PM HI, my 98 sportage has same problem. I have replaced plugs, coils, wires, computer, and crank sensor, and no change, Cylinders 1 and 3 are dead. let me know if you fixed yours and what problem was. thanks goinbig 09-30-2004, 08:40 PM Do the 2 other cylinders have no compression at all? andrew348 10-14-2004, 07:35 PM where the injector harness meets the engine harness there is a connector that like to rust you will have spark in the cylinder but no injector pulse by the way the connector is behind the head along the firewall its hard to gain access to it i would check for injector pules before attempting to look at connector best of luck also these engines like to jump timing if all else fails check compression and valve timing Automotive Network, Inc., Copyright ©2012
