car alarm won't turn off
Sooper
08-09-2004, 12:39 PM
I'm having an issue with my '95 626. The alarm will not turn off. In fact, it seems to be stuck in a loop of trying to arm itself repeatedly, as I can see the lock on the driver's side door kind of "pulse" as it tries to lock itself repeatedly. The remote does nothing to turn it off, or do anything, in fact. I replaced the battery on the remote and it did no good. I cannot start the ignition on the car. There is a switch under the dashboard, but I've tried flipping it to no effect. Anybody have any ideas?
dwinthrup
09-09-2004, 02:47 PM
pull the fuse and find a diff alarm mine i goofy togoes off when nobody is around
ponchonutty
09-12-2004, 11:30 AM
What kind of alarm is it? Usually there is a push button that's called a "Valet" switch that is used to manually shut them down. Normally to use these, you need to turn the ignition on then press this button once or more times depending on how the alarm was set up.
sinaloa67chevy
09-20-2004, 07:37 PM
does you dome light work check and make sure its not staying on. a door switch or truck switch may be showing open
