PLEASE HELP! B16A wont start up!
Fishcat37
02-03-2002, 01:01 PM
hey all- i have an 89 crx si. we JUST put in a B16A SIR1 cable trans in it. everything is all wired up and connected. the thing cranks over, but the problem is that we are not getting any spark at the ignition coil. any help that you can give me ASAP will be much appreciated.
Si2000 Vtec
02-03-2002, 04:03 PM
Make sure and check all your fuses. Did you pull your plug out and ground it while turning the engine over? Are you sure its a spark problem? Did you try turning the key? :)
Tofuboy
02-08-2002, 02:01 AM
Check your distributor assembly
