Please Help! B16 Won't Start Up!
Google
Web AF
Fishcat37
02-03-2002, 12:58 PM
Hey all - i've got the 89 crx si, and we JUST put the B16A SIR1 cable type. everything is all wired up and connected. it turns over, BUT WE HAVE NO SPARK AT THE IGNITION COIL! we dont know what to do and if you could give me any help ASAP it would be HIGHLY apprectiated.
EightOhOne
02-03-2002, 08:09 PM
is it throwing any codes at the ecu?
it could be that its bad...i hear thats somewhat common among those swaps
id check my connections everywhere again...and check your grounds as well first
90CRXZCSi
02-03-2002, 10:06 PM
yea...recheck your connections and make sure everything is ok. Also if you say your not getting spark then check the distributor ,etc.... and all the connections that have to do with it and see if that's the problem. Also like eightohone said...check your ecu to see if it's throwing any codes and maybe see what the problem is.
Phatwhippin_CRX
02-05-2002, 12:18 AM
Make sure you have good grounds.... chances are, you forgot to ground the tranny :)
Google
Web AF
