idle con trol valve 98328ibimmerman333 08-06-2004, 12:19 PM 98328i have a diagnostic done it only costs between 50-100 dollars, to see if any sensors are complaining, but if its running fine and check engine light is not on, i wouldnt worry about it too much. bimmerman333 08-06-2004, 12:27 PM you may want to check air filter and make sure it is dry, you dont want water to get in to the motor , could lead to vapor lock , very uncool. 98328i 08-06-2004, 05:28 PM I will do so! My check engine light turns off, but my airbag sensor light stays on now I heard if the contacts get wet they need to dry off and they will reset.... Do you think spraying WD-40 on the conection under the seat will clear it up? bimmerman333 08-09-2004, 10:45 AM That Might Do It But If Its Water Logged Take A Blow Dryer To It. Good Luck Automotive Network, Inc., Copyright ©2012
