Air compressor going out..IntoxicateMe 08-06-2004, 10:36 AM Well my ac compressor went out..and we didn't have hte money to fix it. So we baught a shorter belt and bypassed the ac compressor. Now my service engine light stays on all the time, is that normal? wakeboardr99 08-18-2004, 08:13 PM most of your best prices will be on ebay, typically they will range from 40 to 170 depending on used or new and how good of a deal you get. As for installing it probably cost 50-150 depending on the place. Most places won't install the parts you have, but make sure that if you get them to do everything , they don't charge you too much over for the part what you can pay for it. IntoxicateMe 08-25-2004, 08:14 PM anyone? sierrap615 08-26-2004, 01:25 AM year/model? define "when out" did it seize or stop blowing cold or something else? any is the SES light always on or only on with a/c? does the cooling fan always run when engine is running? any other info would help. IntoxicateMe 08-30-2004, 07:22 PM It's a 1993 SC1. And the a/c compressor went completely out. It just stopped working. It made this racket, and eventually it looked like the belt was gonna pop off. So we went down and baught a shorter belt to bypass the air conditioner. Now the Service engine soon light stays on all the time. sierrap615 08-30-2004, 11:44 PM ok, lets see if i can explain this right... the belt is on the pulley. the pulley is not directly attached to the compressior pump, there is a clutch inbetween them so the A/C can be turned on and off. simular to the clutch in a transmission. if just the pump seized, the pulley should still turn. since the pulley would not turn, that would lead me to beleve the clutch or pulley are seized. this next thing is unlikely and just me ranting ---> another thought is sence its a 93, it may have come with R-12 refrigerent from the factory, if the system was ever recharged, they would have converted the system to R-134a, since R-12 is near impossible to get now days. but R-12 and R-134a can not be mixed, the system has to be completely cleaned when converting. if the system wasn't completely flushed out the pump could be damaged, but it shouldn't affect the pulley/clutch. anyway- for the code under the dash, by the hood poper, there is a termial, 2 high, 7 wide i think. there will be only three wires hooked up to it. all on the right side, two on top one on bottom. with the key on engine off, put the paper clip in the two top holes, shorting it out. the SES light will blink the codes. IE one blink, pause, two blinks, pause is 12 three blinks, pause, six blinks, pause is 36 each code is repeated three times, then it goes to the next code, once all codes are read, it goes back to the first and repeats. the first code is always 12, its "Diagnostic System Check" the codes are: Diagnostic Codes 11. Transaxle Codes present 12. Diagnostic System Check 13. Oxygen sensor, circuit open or not ready 14. CTS circuit, out of range high 15. CTS circuit, out of range low 17. PCM fault, pullup resistor 19. 6x signal fault, no 6x signal between reference pulses 21. TPS circuit, out of range high 22. TPS circuit, out of range low 23. ATS circuit, out range low 24. VSS circuit, no signal 25. ATS circuit, out or range high 26. Quad Driver output fault 32. EGR system fault 33. MAP sensor circuit, out of range high 34. MAP sensor circuit, out of range low 35. IAC valve, rpm out of range 41A EST circuit open 41B EST circuit shorted 42A Bypass circuit grounded 42B Bypass circuit open 42C Bypass circuit shorted 41. EST bypass, open or shorted 42. EST bypass, open or shorted 43. ECS (knock sensor) circuit open or shorted 44. Oxygen sensor indicates system lean 45. Oxygen sensor indicates system rich 46. Power steering pressure switch circuit, open 49. Idle rpm out of limit high (vacuum leak) 51. PCM memory error 55. A/D converter error in PCM 81. ABS message fault (1993 vehicles with TCS) 82 PCM internal communication fault Diagnostic Flags 27. Quick quad driver output fault (1993 only) 48. Reference imput intermittent or noisy 52. Battery voltage out of range 53. ESC knock present 54. Five volt reference ground 58. Battery voltage unstable 61. 6x signal fault 63. Option check sum error 67. Handwheel sensor circuit fault 71. Cooling system temperature high 72. Coolinng system temeprature low 73. CTS sensor unstable 74. CTS/transaxle temperatuer sensor ratio error 76. ATS sensor unstable 83. Low coolant (1993 only) i bet the code will be 26, the quad driver controls the A/C clutch if this doesn't lead you anywhere, ask the techs on saturnfans.com/forums Automotive Network, Inc., Copyright ©2012
