91 Civic 'Bucking'TeLNeTD 05-23-2001, 08:57 PM My 91 civic hatchback sometimes shakes... Often after high RPM but not always. The engine SOUNDS like it's running great with a shot of gas....but when it idles I sometimes get this "Bucking, Shaking" in the engine Anyone have any ideas? Scott enzo@af 05-23-2001, 09:30 PM Do you need to advance the timing? Just a thought..said it idled rough. Or, maybe you need to change your plugs or something. (is it missing?) TeLNeTD 05-23-2001, 09:37 PM Well.. THe timing is QUITE possible... I tried to check the timing one time but I can't make out the marks on the crank pully... What about manually adjusting it... Ie... While the car's running... Is that possible? I want to chenge it to see if that's the problem but I don't want to screw it up :) BTW: New plugs JD@af 05-23-2001, 11:54 PM Does your car ever have trouble starting up? Ever any hesitation at stop lights (i.e. when the light turns green)? TeLNeTD 05-24-2001, 10:18 PM Yes, Very badly when she's cold... Mostly in the winter. But when she's at normal operating tempreture, It's not bad. Automotive Network, Inc., Copyright ©2012
