00 z smokin when start but thats it.
jayson716
08-04-2004, 03:09 PM
Any1 know why my car would put a small amout of black smoke it only happens on start. then goes away and the car runs fine it has 60 k on it.
i have intake. borla cat back exhaust
airmankracker
08-04-2004, 03:54 PM
does that borla catback create alot of sound?
about your problem...i don't know tons about cars but could it be possible that the smoke is caused by oil leaking where it shouldn't when the car is turned off? brain fart about the details but that may give you an idea.
public
08-04-2004, 06:29 PM
Oil smoke is blue.
Fuel smoke is gray or black
antifreeze, tranny fluid, and brake fluid make white smoke.
black smoke on start up may indicate that you have a leaking fuel injector. You may wish to try some cleaner in case it is just sticking open a little.
jayson716
08-04-2004, 08:27 PM
Thank you... well i work as a plumber and work on boilers so i know when the fuel air mix isnt right i get a black smoke. so my question is how can a leaking injector cause that problem? by dropping fuel while off?
jayson716
08-04-2004, 08:28 PM
and i have a pacesetter header and yea it sounds ok not a ricey sound a more deap throaty sound
Three_Fingers
08-04-2004, 09:01 PM
Malfunctioning CTS can cause an over-rich start. (THinks it's colder out than it really is-telling ECM to hold injectors open for an even wider than necessary pulse width)
Dirty air filter will cause it.. (Air intake restriction)
Malfunctioning IAT will cause it. (Thinks intake air is colder than it really is. Same reaction as CTS)
Malfunctioning fuel pressure regulator will cause it... (Too much fuel pressure at injectors when cold)
Incorrect spark plug gap will cause it. (Cold conditions require different spark timing that hot conditions.)
Bad, leaky plug wires will cause it. (Wires that leak current when cold/damp, but work OK when hot and dry.)
(won't fire so good at rich mixtures, but hot, lean condition OK.)
Bad ECM ground will cause it. (Erroneous data from sensors to ECM du to intermittent bad connection, which heat will tend to tighten temporarily.)
Malfunctioning MAP sensor (THinks it's at a higher altitude than it really is.
Don't worry about the O2 sensor-The ECM ignores it usually until it's temp reaches 600 degrees F or two minutes thereabouts has passed.
The ECM uses info primarily from the CTS and IAT sensors to calculate mixtures for an initial cold start.
jayson716
08-04-2004, 09:39 PM
well kinda hoping it is just somthing with injectors... i dont want to be messing with all that lol... but if i have to i will. i plan to get new injectors and a fuel rail just having a hard time finding one so any advice is appreciated
But thanks for the advise
public
08-04-2004, 10:09 PM
A leaky injector can "drip" while the car is off. When you start it is a little rich and you get a puff or two. If that don't fix it you may still need to check all the things Three Fingers mentioned.
But you always start with simple and cheap first. Good Luck.
jayson716
08-05-2004, 06:52 PM
well i thanks for the help and yes it is just a puff of black very minimal. when it happens i cant even see it by the time i turn around.. but when some1 else starts it as i am watching i can see it for a sec...
