suspension on 98 328r8rferg 08-04-2004, 01:47 PM i need to replace my rear bushings but i'm not sure which ones to order. if someone has a diagram of the suspension or knows where to get one i would appreciate taking a look at it. I'm not sure how many options i have for rear bushings (could be control arm bushings i'm not sure) but if anybody knows which ones i would likely need to order let me know. Thanks for any help you can give me. jeffreyb4me 08-04-2004, 07:35 PM There's a number of bushings and rubber mounts, I'd ask which but your not sure.....why do you need to replace them [it] ??...................... .jeffb. r8rferg 08-05-2004, 01:59 PM i think it is the lower control arm bushing (lowest and most forward bushing in the rear). its hard to tell because i don't have a diagram to go by or the dimension of the bushings. i should recieve the ones i ordered today and will find out if they are correct. i just wasn't sure if they were the right ones. i need new bushings because my old ones are worn out and the car is able to shift side to side on the suspension. thanks for the response Automotive Network, Inc., Copyright ©2012
