Envoy Navigation Radio Upgrade??Rainylaker 08-03-2004, 05:10 PM I have a new 2004 Envoy with 6 cd changer and bose system. Anyone have info on an upgrade to the Navigation Radio and adding an external cd changer somewhere else in the car?? Thanks! DomC 08-05-2004, 03:12 PM Yeah can upgrade the system with the Delphi Nav system Part# 15204335. You may not be able to get this from the dealer, If so am sure it's way over priced. Best place to look is on ebay. am about to the same to mine. The only thing is you have to have the dealer program the vin number into the radio. FplcMan 01-31-2005, 12:33 PM I have a new 2004 Envoy with 6 cd changer and bose system. Anyone have info on an upgrade to the Navigation Radio and adding an external cd changer somewhere else in the car?? Thanks! I found all the info I needed here: http://www.gm-trucks.com/forums/index.php?showtopic=28030&st=0 This is a long post but has a lot of info. Thanks FplcMan Tecknology 02-01-2005, 04:28 PM Most upgrades at this point with the Envoy models involve software upgrades so you may want to look at that too. Chriznat20@msn.com 02-01-2005, 10:01 PM I would like to upgrade my 6 disc BOSE system to the NAV system in my 2002 Envoy. I have OnStar also. Would it be a direct swap with a NAV unit from a 2002 GMC? FplcMan 02-01-2005, 10:40 PM I would like to upgrade my 6 disc BOSE system to the NAV system in my 2002 Envoy. I have OnStar also. Would it be a direct swap with a NAV unit from a 2002 GMC? The Nav headunit will be a direct swap for your factory headunit. There is a VSS (vehicle speed signal) wire that can be added to your headunit harness to make the movement on the navigation a little smoother but it is not necessary for it to work. the nav unit you will want to use is: #15108421 (INR) or 10377287 (TNR) and the antenna #15135178. It is a direct swap for 2003 and up because of the data bus..... Chriznat20@msn.com 02-16-2005, 07:22 PM "#15108421 (INR) or 10377287 (TNR)" Whats the difference between the two head units? What does INR & TNR mean??? FplcMan 02-17-2005, 09:42 AM "#15108421 (INR) or 10377287 (TNR)" Whats the difference between the two head units? What does INR & TNR mean??? The 421 is the 04 model. The 287 is the 05 Model. The 287 is touch screen and the 04 is not. Look here for all you answers http://www.gm-trucks.com/forums/index.php?showtopic=28030&st=400 rajudeep 08-25-2005, 11:23 PM I have 2004 chevy traiblazer and i would like to install navigation.i do not have bose system .Any body has any idea what parts # i need? Thanks in advance Automotive Network, Inc., Copyright ©2012
