00 Cav revving high at idlestevehollinger 08-03-2004, 03:02 PM My manual 2000 Cavalier Z24 has recently started to rev at or above 1400 rpm (sometimes as high as 2000 rpm), as opposed to the normal 1000 rpm at idle. It happens all the time now, while in gear, with the clutch engaged, or simply in neutral. The air conditioner is not on. My check engine light is on, and has been for quite some time now, as I have prolly blown another sensor that the cavaliers are so famous for...that's a topic for another day. Any suggestions as to the problem? Expensive? Thanx Vissora 08-03-2004, 05:45 PM i think your fuel pump is probably going because thats what happened in my car and that would cause the check engine light too. lowS-DIME 08-04-2004, 03:25 AM try fuel filter first... it would suck to spend the money on the pump and turn out that it was just a fuel filter... how many miles r on the car? stevehollinger 08-04-2004, 08:24 AM There are 75,000 miles on it. lowS-DIME 08-05-2004, 12:24 AM check filter... i dont think ur pump would go out untill about 95,000 to 100k Three_Fingers 08-05-2004, 12:05 PM Best bet is to get it scanned. Sensor tag can be very expensive. Guessing rarely works-as you're playing chess with a hidden opponent with it's own bag of tricks. Automotive Network, Inc., Copyright ©2012
