Dome light Dead...Frozen001 08-02-2004, 07:56 AM I was recently installing a security system on my cousins 2001 Grand Am, an while working on it the dome light simply stopped working... no bad fuses, and the bulb is good. I tested the plug with a meter, and there is no power even reaching the light bulb. Any ideas on what might have happened. BTW when it stopped working I was not even doing anything to the wires on the car.... GASE 95 08-02-2004, 08:30 AM what were you doing when the light went out? Frozen001 08-02-2004, 08:48 AM Well, actually I was looking at the wire on the dome light to see if I could trace them back to a better location on the car to connect to the alarm system. I was not using anything that could have shorted something out; just sort of pulling down on the case and looking at wire colors (which are black, white and orange, black and white are ground and orange is the power I think??) I am totally baffled by this. I was able to trace this wite back to the massive wiring block by the dash fuse panel, and there is no power there either. GASE 95 08-02-2004, 09:00 AM ok i dont think that black AND white are grounds...should just be the black. Theres no need for 2. Orange is usually connected to a switch or relay so that should be ur hot wire. White is usually an ignition wire but that doesnt make sense in this case. I dont know how you couldve caused it to quit unless while pulling on the cover you somehow pulled a wire loose. But that doesnt make sense either since you have no power by the fuse box. Is there anything else thats not working properly? Frozen001 08-02-2004, 09:11 AM ok i dont think that black AND white are grounds...should just be the black. Theres no need for 2. Orange is usually connected to a switch or relay. Im thinking that the white should be ur hot wire. I dont know how you couldve caused it to quit unless while pulling on the cover you somehow pulled a wire loose. I pulled the light out completely after it stopped working and checked the connections. Black and white show 0 ohms to ground and the orange is open. Frozen001 08-02-2004, 09:15 AM I pulled the light out completely after it stopped working and checked the connections. Black and white show 0 ohms to ground and the orange is open. BTW.... The dome light has a switch on the light it self to turn it off/door/on, and there is also a panel switch to turn it on/off (this is the usual on in with the panel light dimmer) Pvt_Murphy 08-07-2004, 08:40 PM I pulled the light out completely after it stopped working and checked the connections. Black and white show 0 ohms to ground and the orange is open. Black should be ground and Orange should get power when the key is on and the lights are turned on; I think maybe white powers the 2 lights for the rear passengers and the orange might go to the main one to turn it on when door is open. But Black should be gound. Tom94gaGT 08-08-2004, 12:15 AM Is it just the dome light or all the courtesy lights? b/c i know that on my car all the courtesy lights stopped working and i checked everything, and turned out that the switch on the driver's door was stuck and thats why the lights werent going on? just a thought Automotive Network, Inc., Copyright ©2012
