Ok lets see if I got this right.. you want to win but not use a lot of money? hmm hypertech tuner..reprogram gas octane, speed rating, firm shifting, and tire sizes would be a start, that will cost you about 300-400 depends on where you buy it. Now a good decent intake system would be good. More air = GOOD with that intake will you need an aftermarket exhaust or else you will lose power. Cause think the new intake will stuck more air in but that stock exhaust wont be able to spit more out because it was only made to spit out the stock amount. An intake system will be around 120-300 depend on what you get..I will recommend the K&n gen II comes with everything install about an hour. The exhaust will go from anywhere 300 and up. Custom jobs are expensive but gibson edelbrock and borla sell some really good quality exhaust systems. Comes in a set install by self about 3-4 hours. Now with the more breathing and computer program makes the engine run harder.. you will need a lower degree thermastat. Buy one for about 40$ at your local pep boys or auto zone. Your car should come with a stock about 180 degree thermastat try to buy a 160 degree. The install for that will be about 15 minutes. directions com with it so dont worry. Now if this is going to be a simple race just cut yopur cats off while your at it.
O yea a mass air flow sensor should help too. But every little.. You can buy it online for about 350 and installation is right between the air filter and connecting hose about 15 min job. So we got the intake, exhaust, thermostat, computer programming, mass air flow sensor.... also make small checks like air pressure and check you oil make sure it at a good running level. If you have time and really want to win then start taking seats out because the denali seats having heating on them making them weigh about 200 pounds each...this should help you beat your friend......
