oil pressure....mike89lxi 02-01-2002, 10:36 PM im trying to hook up my oil pressure gauge and it says to hook the nylon pressure tubing to the appropriate pressure port on the engine block. does anyone know how i should hook this up or where to? thanks. Hondahottie 02-02-2002, 01:43 AM right next to your oil filter should be an oil pressure sensor. just buy a T-fitting and replace the sensor with it, then reinstall the pressure sensor on the end and the fitting into the side. Honda's oil pressure sensors use a BST thread, so u may have to rethread the T fitting to fit. 89ssgti 02-02-2002, 01:47 AM Originally posted by Hondahottie right next to your oil filter should be an oil pressure sensor. just buy a T-fitting and replace the sensor with it, then reinstall the pressure sensor on the end and the fitting into the side. Honda's oil pressure sensors use a BST thread, so u may have to rethread the T fitting to fit. and the oil pressure is indicated on that image http://hybrid.honda-perf.org/tech/sohcvtec/coolant.gif it's about the same for every Honda engine:bloated: mike89lxi 02-02-2002, 04:48 PM thanks for the help. also, where can i get a "T" fitting that i need? and does anyone know where i can get some real small nylon hose? thanks. Automotive Network, Inc., Copyright ©2012
