Just raced my 97GT in the quater mileblake andrade 07-31-2004, 03:36 PM Hello, Im new to the forums and I just raced my 97' I raced it at our local drag racing track just to see what it could do and I was tired of everyone ragging on my 4dr car being a slow ass beast. I took one of my friends along for kicks and we went to the track. I asked a few people what it could do and everyone was thinking in the low 17 seconds. I raced it and the first run I did with my friend in the car was 16.518 seconds!!! After a couple more runs we decided to put in the K&N filter we bought earlyer and it did roughly the same. but then I did one last run for the night alone and I manually shifted my automatic. You wouldn't belive it but I ran a 16.223!!! anyone have any cheap mods I could do to just scrape into the 15 second bracket? Ripn12s 07-31-2004, 04:41 PM Quivrynn 08-01-2004, 07:51 PM Aye' everyone always underestimates the power of a manual-auto trans. Good for you. AKWE-gt 08-01-2004, 10:27 PM first mod is get a shift kit. even with manually shifting these trannys your going to shave alot more time off your e.t. with a good shift kit. RedLightning 08-01-2004, 10:36 PM but doesnt manualy shifting with an auto wreck your transmission? anyways how do you do it? AKWE-gt 08-01-2004, 10:49 PM you don't want to shifting down manually to often that's where you'll be doing the most damage, gears don't like being meshed violently. shifting manually is just taking the shifter and shifting the tranny into first gear and working through the gears yourself instead of the tranny. GTPCatz 08-01-2004, 10:50 PM you don't want to shifting down manually to often that's where you'll be doing the most damage, gears don't like being meshed violently. shifting manually is just taking the shifter and shifting the tranny into first gear and working through the gears yourself instead of the tranny. you mean "instead of the PCM (computer)" RedLightning 08-02-2004, 08:08 PM you don't want to shifting down manually to often that's where you'll be doing the most damage, gears don't like being meshed violently. shifting manually is just taking the shifter and shifting the tranny into first gear and working through the gears yourself instead of the tranny. i should try it on my parents car. Melvyn_with_a_GTP 08-03-2004, 02:01 PM I race my 97 gtp at the 1/4 mile. I always shift manualy with the auto-trans. If you do it right it will shift at just a little higher Rpm. I know in mine it will shift to second gear even when my lever is still in first gear(??) so doing it in first gear does not seem to help but going into third it helps (but just after that shift ive gone a quarter mile.) kman10587 08-03-2004, 02:04 PM First mod: race without your friend in the car. Extra weight = bad :) AKWE-gt 08-03-2004, 11:31 PM but if the friend is a hot girl who gets turned on by speed than, extra weight=good! BFT 08-04-2004, 03:07 AM Hit club GP.comm see the L36 forum. You will be running 14's soon. PJVargy 08-14-2004, 09:55 PM All this talk about manually shifting is worthless. When racing with a stock pcm, you should launch in 2nd gear. Later before the car shifts to 3rd gear, shift up into 3. When you try and shift manually, the computer does its own thing anyway. You basically have no control over shift points. In other words, its a bad idea, and a good way to really wear on your transmission. I got my GT down to 15.1 using this shifting method. leadfootGTP 08-14-2004, 10:33 PM All this talk about manually shifting is worthless. When racing with a stock pcm, you should launch in 2nd gear. Later before the car shifts to 3rd gear, shift up into 3. When you try and shift manually, the computer does its own thing anyway. You basically have no control over shift points. In other words, its a bad idea, and a good way to really wear on your transmission. I got my GT down to 15.1 using this shifting method. PJVargy - your FOR manually shifting, no your AGAINST manually shifting, NO, your FOR manually shifting, No, your AGAINST manually shifting!, right i really cant decide, 1. [against it!] you say its worthless (All this talk about manually shifting is worthless) 2. [for it!] you recoment using a methoud of manually shifting (you should launch in 2nd gear. Later before the car shifts to 3rd gear, shift up into 3) 3. [against it!] you say manually shifting is a bad idea (When you try and shift manually, the computer does its own thing anyway. You basically have no control over shift points. In other words, its a bad idea, and a good way to really wear on your transmission.) 4. [for it!] you say that by manually shifting you decreased your QM time (I got my GT down to 15.1 using this shifting method) mabe explain your post a little more.... AKWE-gt 08-15-2004, 10:40 PM is there anyone making a manual trans for these cars? i know there was some manual gp's in the early 90's i wonder if any of those engineers at GM will ever get their head out of their asses and put some sticks in these cars. my sister had sentra seR ,with a 4 banger and a 6speed stick, man that was nice to drive but wouldda been better in a gp. 94sportsedan 08-17-2004, 01:16 AM can use one out of the chevy cavaliers with the 2.4L I believe, a getrag 5 speed. Should bolt right up to the engine. AKWE-gt 08-18-2004, 01:06 AM but what's the torque rating on that tranny? that would be too sweet if this thing could handle a 3.8. the cockpits in these cars are made for a stick, it has the same feel as my old 87 formula. 94sportsedan 08-18-2004, 01:34 PM Not sure but I saw it in a website, he put it put a 3.8 SC engine into a cavalier using his cavalier 5 speed transmission. GTPCatz 08-18-2004, 05:50 PM If your talking about the same guy that Im thinking of....he killed that Transmission with all the torque! 94sportsedan 08-18-2004, 11:40 PM oh well , guess was a bad idea then. I did have a 1995 caprice which I installed a t56 six speed manual. Was like a totally different car. BPM 08-21-2004, 12:17 AM To get the most of your time, launch w/the car in 2nd. There is a fail-safe that will automatically shift into 2nd if you're in 1st, so launching in 1st is useless. "Manually" shift into 3rd just before redline. This will give the trans time to shift and you'll get the most out of your high RPMs. I highly doubt this causes any additional transmission wear. If anything, it may very slightly contribute to accelerated clutch wear. Get a shift kit to avoid this. Automotive Network, Inc., Copyright ©2012
