Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo/Passport
Old 07-31-2004, 09:45 AM   #1
keithf99
keithf99 Normal reputation
Changing wheel studs
I have 1997 2 wheel drive rodeo. I need to change one of the front studs. Do you have to pull the front hub and wheel bearings or does the rotor come off on its own? I think I read on this forum that it takes a special socket to pull the front wheel bearings. Is this right ?
thanks
keithf99 is offline   Reply With Quote
Old 10-12-2004, 11:34 PM   #2
jstonefish
jstonefish Normal reputation
Hub and rotor assemblies need to be separated to change wheel studs. Removing the 3 philllips head machine screws from the "wheel nut washer" can be problematic. Once you get that done, Performance Tool part # W83007 (~$12) will be helpful. I found one at Tool King. Once that wheel nut is removed, it will all be obvious. Not a great way to spend the weekend.
jstonefish is offline   Reply With Quote
Old 06-24-2005, 11:23 PM   #3
v6stang108
v6stang108 Normal reputation
Re: Changing wheel studs
That special tool is recomended. It took me but 15 seconds with a punch and a VERY lite tap of a rubber mallet, at a lefty loosy angle, to get the retaining nut off. Just don't use the holes the little screws were in. If you are new to bear changes I'd say go ahead and get the tool.
v6stang108 is offline   Reply With Quote
Bookmarks
Google
Web AF
