"Bogging" at low speedsMr. Cynical 07-30-2004, 06:49 PM Good day, everyone! A while back, I posted that I was experiencing a problem with low-speed acceleration. Advice given was to check the tranny fluid and perhaps the fuel filter. Well, the fuel filter's changed, and the transmission fluid is good too. I'm still bogging down at low speeds. I notice it most when I'm going around corners in my neighborhood, and in traffic. (Today, I had my coolant flushed, not that it's related, but just thought I'd add that in there as well.) Also, today I noticed that the "Performance Shift" wasn't lit up at a point where I turned it on. If I throw the car into either neutral or park, it comes on, but when I move it back into a drive gear (or rev the engine while it's in neutral or park) it goes back off. Folks, this is my daily driver, and I'm on the road for work every day around Denver. Anyone got an idea? I'm definitely on a budget for the next couple weeks, and I'm afraid that if it craps out on me, I might lose my job! Your Pal, Mr. C. bbuckli 08-06-2004, 05:28 PM Hey Mr. C, Not to long ago I was experiencing some problems similar to yours. I tried to fix them my self but nothing came up, no service engine light, no nothing. I finally ended up taking it to a local shop and they found out that it was leaking antifreeze through the plannium gasket which is right by the throttle body. A week and 600$ later i got it back and it ran fine for 200 miles but im experiencing that same problem again but even worse this time. Grand Prix's are known for the problems with antifreeze locking up the cylinders. I know a few that have had the same problem with Gp's over 110,000 miles. thought maybe that might be helpfull, doesnt hurt any. Post a reply if you find the problem, i would like to know so i can get some ideas. Thanks, Buck Mr. Cynical 08-07-2004, 01:11 AM Hey Mr. C, Not to long ago I was experiencing some problems similar to yours. I tried to fix them my self but nothing came up, no service engine light, no nothing. I finally ended up taking it to a local shop and they found out that it was leaking antifreeze through the plannium gasket which is right by the throttle body. A week and 600$ later i got it back and it ran fine for 200 miles but im experiencing that same problem again but even worse this time. Grand Prix's are known for the problems with antifreeze locking up the cylinders. I know a few that have had the same problem with Gp's over 110,000 miles. thought maybe that might be helpfull, doesnt hurt any. Post a reply if you find the problem, i would like to know so i can get some ideas. Thanks, Buck Well, it can't hurt to check it out! I'm planning on changing the plugs/wires, as well as perhaps the tranny filter. Let's hope it gets no worse! GTP Jeff 08-07-2004, 10:31 AM For a low speed bog like that, the first thing I'd suspect is the throttle position sensor or a vacuum hose that's become detached.. Mr. Cynical 08-07-2004, 11:10 AM For a low speed bog like that, the first thing I'd suspect is the throttle position sensor or a vacuum hose that's become detached.. The vacuum hose sounds easy! I'll go look for that soon! I wouldn't know how to check the TPS, but I'm sure someone will :) GTP Jeff 08-07-2004, 03:26 PM I can't tell you specificly how it's done on Grand Prix's.. But I can tell you how it was done on Mustangs.. Throttle Position Sensors are nothing more than a varible resistor, but they cause more than there fair share of drivability problems.. They are very sensative to getting wet.. So if you've washed your motor, it may have screwed your TPS up, if you didn't protect it.. Plus, they can wear out from just being mechanically opened and closed every time you step on the gas.. Your cars computer sends a voltage to the TPS (usally around 5 volts), and measures how much comes back.. That tells the computer how far the throttle is open.. Something like 1 volt means the throttle is closed, and 5 volts will mean it's wide open.. Part throttle is everything in between.. The testing procedure goes like this.. Using a digital voltmeter, pierce two wires coming from the TPS harness with safety pins.. You may have to switch wires or polarity to get the reading you want.. Usally one wire is ground, another is the supply voltage, and another is the return voltage..You want the return voltage and ground.. Once you meter is hooked up.. With the Key On Engine Off, you should have a specific throttle closed voltage (I don't know it for GP's).. But "most importantly", when you open the throttle by hand, the voltage reading should rise and fall in a linear manner.. If you can move the throttle a little and the meter doesn't go up.. And then when you move it a little more, the voltage shoots up.. You know the sensor is bad.. If the TPS has the correct closed throttle voltage, but just doesn't respond in a linear manner.. It will cause a stumble, but not give a fault code.. The rapid change in the TPS voltage is what causes the injectors to act like accelerator pumps in a carburetor.. When you blip the throttle, the computer tells the injectors to give a little blast of fuel, so you don't get a stumble.. Mr. Cynical 08-09-2004, 11:22 PM Well, just a couple weeks to go, and PAYDAY! The company owes me a chunk of change from last month, and I plan on sinking it into my car until it works right! I'll be first changing Plugs, Wires, and TPS. From there, I'll report as to what I've noticed (whether there's improvement) and will go from there :) And, to be smart about things, I'll test things out in between each item, so that maybe I can isolate where the deal is for some other schmo down the road with this stupid problem! ;) richtazz 08-20-2004, 01:16 PM your trans light acting crazy might indicate a bad tcc. This will cause the torque converter to lock when it shouldn't and make it boggy on acceleration, similar to a stick shift car in too hig a gear. you can temporarily unplug the tcc connector, which will not allow the tcc to lock and eliminate this as a cause. The connector is located on the drivers side of the engine compartment in the front, just under the air intake tube. It is a square plug with 4 wires Mr. Cynical 08-20-2004, 01:32 PM your trans light acting crazy might indicate a bad tcc. This will cause the torque converter to lock when it shouldn't and make it boggy on acceleration, similar to a stick shift car in too hig a gear. you can temporarily unplug the tcc connector, which will not allow the tcc to lock and eliminate this as a cause. The connector is located on the drivers side of the engine compartment in the front, just under the air intake tube. It is a square plug with 4 wires THAT'S what I've been trying to describe; the feeling like it's in too high a gear. I will wait till it cools off, and go unplug it for the drive home and report back what happens. Thanks! troy1 08-20-2004, 02:06 PM If the torque converter is locking up at 20 - 25 mph thats way to soon, There is a little tiny filter on the VB plate under the side cove that spins and gets cut off under light trottle SOMETIMES it will not lockup the converter and if you get into it more it will. This really bogs down the motor because you engine can not rev up troy1 08-20-2004, 02:09 PM If the torque converter is locking up at 20 - 25 mph thats way to soon, There is a little tiny filter on the VB plate under the side cove that spins and gets cut off under light trottle SOMETIMES it will not lockup the converter and if you get into it more it will. This really bogs down the motor because you engine can not rev up this is very common on the 4t60's and if the TC is coming on you will know it it comes on hard sometimes. Mr. Cynical 08-20-2004, 09:10 PM I just got back from my local Checker Auto Parts, where I got them to give me a scan. The results? No Codes. The guy who was doing it thought it was odd, since in his words, "Your car will blow a code if the air filter is bad." So, I guess I'll have to find some tools and remove the airbox to try the TCC plug trick. If that doesn't work, I'll be replacing the plugs and wires on the 30th (Thank GOD for paychecks!), and will report back with what's what. Mr. Cynical 08-22-2004, 10:46 PM Still no clue as to what's going on. I noticed today that the transmission fluid is a little high. Not like CRAZY high, but enough that I wondered if that could be a problem. According to what I'm reading, when the transmission fluid is high, it can get frothy, and thus lose its ability to function in both shifting and cooling. Since there's no drainplug for the transmission, I'll be dropping the pan anyway. I'll change the filter at that time, and see if that fixes things. I'd rather not have to try and find the TCC solenoid if I don't have it! richtazz 08-24-2004, 09:32 AM if your fluid was too full, you'd see bubbles on your trans dipstick. I would still look at the tcc, as they don't always trip a code when they start to stick intermittently. Aqualls1 08-25-2004, 10:34 AM I have the same problem, I subcribed to all data yesterday and found that the ho2s is the first thing to check. If its response is too slow it will cause this problem. I have some checking to do I have a problem with my ignitions switch (which supplies the power) so I'm going to make for sure it is getting power before I replace it. Aqualls1 08-31-2004, 01:52 PM Replaced o2s last night, no change... I've changed plugs and wires, coolent temp, IAC, checked the MAF and tps, and now I have replaced the front o2s. I'm at a loss. The question now changes from what can it be to whats left. Mr. Cynical 08-31-2004, 11:02 PM I hope this is not making you as nuts as it is making me!!! Phoenix69 09-01-2004, 05:49 PM Do any of you notice that at around 46mph, i believe 3rd gear, you accelerate more easily? It feels like my car wants to go fast at that point. Mr. Cynical 09-01-2004, 07:09 PM Do any of you notice that at around 46mph, i believe 3rd gear, you accelerate more easily? It feels like my car wants to go fast at that point. I notice that mine, when it's cold, runs really nicely still (or at least comparatively). When it heats up, that's where it wusses out. I think I notice what you're referring to, as long as I'm not cruising at 45 or so then try to accelerate. If that's the case, then it seems to...just not be pulling right. If I stand on it from a stop, it does seem to pull harder once it works up a gear or two. I finally got unbroke (thank god for full time job!) and have purchased a drip tray so that I can try dropping the transmission pan. First, though, I'll remove the airbox and try the TCC plug trick to see if that fixes it. In fact, as soon as things cool down a bit, I'll go pull that plug. If that doesn't get it, I'm going to drain and refill the transmisison to see if there's any shrapnel coming out. When I refill it? I'll refill it to the RIGHT level, not to a bit over. More to come, now that I have tools of my own! Mr. Cynical 09-02-2004, 09:53 PM Bubbles on the dipstick! Mr. Cynical 09-03-2004, 09:44 PM Well, I just drained out about a pint, and it's just now down to the top of the "FULL HOT" line. I took it out around the area to let things really warm back up, and *think* it's acting better. The "Performance Shift" light still doesn't come on when I flip the switch. I'm going to drain it to half-way, then take it around the block a few more times. Reporting back soon. Mr. Cynical 09-04-2004, 12:50 AM Okay, after siphoning some more fluid out to bring it down to what is more normal a level, the bogging seems to be SHARPLY decreased. I'm going to let it cool and settle overnight, then try things out again in the morning fresh. On to the "Performance Shift" indicator. After I figured out how to tear apart the console, the first thing I noticed when I was taking out the shift boot and knob was a black wire, frayed at both ends of where it was cut in half. Of course, the wire went straight to the connector that comes out of the shift knob. After a quick splice, I fired it up, and voila. K.I.S.S. does make sense afer all. On the bright side of all this stuff: Underneath the shifter, I found a cigarette lighter that looks to have been there for years. It was lying right on the metal, and was NICE and hot. The moral of the story is that if you've got something torn apart, have a look around! You might be surprised what you find. Automotive Network, Inc., Copyright ©2012
