97 acting rather strange
groovin73
07-30-2004, 02:31 AM
:confused: my car has been acting rather strange. first the rear defroster kept coming on by its self, then i'll be doing about sixty and it was like it died then started right back up it would jerk. the idle is real low and now it's missing. I'm thinking computer any suggestions?? :confused:
topdog2
08-02-2004, 11:31 PM
The defroster sounds like a bad ground. On the other stuff, you need to get someone to pull the codes. could be just a bad sensor,corroded connector,ect. hope this helps.
Alldar
08-08-2004, 03:33 PM
well i had those probs and it was EGR vavle...
dont know about the rear defroster....
groovin73
08-14-2004, 04:58 PM
thnx, it's in the shop now the guy ran the diagnostics on it and everything read fine. so now he's chasing down the wireing harnesss and looking for shorts i guess. i dont know i'm pretty car stupid when it comes to anything more than oil changes and brake jobs. :grinno:
jester4666
08-17-2004, 08:57 PM
i have a 97 cirrus lx that's having really bad issues also. i've been trying to avoid having a shop trace the wiring to find out the problem. it seems the computer isn't talking to the car anymore since the check engine light won't come on anymore. i guess i'll be calling a shop tomorrow about it....and get ready to be charged $60 an hour for labor
harnest
09-09-2004, 01:35 AM
Got serious issues with my 95 Cirrus...tranny won't shift sometimes...dealer says computer bad...replaced it...shifts fine but puter won't talk to the diagnostics so they say wiring harness...also the check engine light on now and speedometer doesn't work. Help!!!
1badredbird
09-11-2004, 03:30 PM
You all need to check your battery (located between driver side front wheel & headlight) cable ends & battery. Clean them REALLY GOOD! There is a cover that you will need to remove to get to the battery, taking the wheel off makes this job much easier, {take my word 4 it}! You should take your battery out, and to Advance Auto, Autozone, or whatever parts store you use, they will test it for free. If your battery tests below 75% capacity(under load), it will render your cloud car mentally challenged, AND, a bad ground will do the same thing! My 96 Cirrus died, the wipers, cruise, came on while switched off, all dummy lights lit up, gas guage dropped (while full), all because I had a bad ground at the battery! I thought that I was in HUGE trouble, but these cars seem to be VERY dependant on a good ground.
I took 80 grit sandpaper & cleaned my battery & cable ends, re-assembled it,(after it tested at 11 volts U/L) and to my astonishment, all was well, and still is!
When having your battery tested, you will need a new one if it pulls it below 9 volts(ask the guy testing for the results!)-that's 75% of 12 volts. Hopefully, this will be at least one of your problems.
Wishing the best, and cheapest fix 4 all! 'bird
