Blower Motor!!!!!3.8literImporteatr 07-29-2004, 11:15 AM Ok, had my share of problems with my 98 GT, the alternator, the headlights falling apart, the brown coolant, the radio steering wheel controls!! Now, I have a new problem, the blower only works on 4, and 5, 2 days ago it worked on 3!! I have seen so many different ideas as to what this problem is, and I dont really wanna have to change the motor, resistor, ing. switch, and everything else, SO, what is the best way to go here, the dealer says to go ahead and change the ign. switch, and harness... Thanks Mike s_jo4 07-29-2004, 11:19 AM sounds like the ignition switch is the winner. not sure of the costs but from different forums and other's posts here it tends to be the best fix. BIG-L 07-29-2004, 01:47 PM sounds like the ignition switch is the winner. I agree also, the ignition switch harness. blacklabel101 07-29-2004, 04:10 PM I had this same problem and all i did was replace the blower motor resistor. Which was good b/c the part only cost about 20 bucks. 3.8literImporteatr 07-29-2004, 06:13 PM thanks, Im gonna try the resistor first before I dive into the ign. switch, and all that fun stuff!! GTP Dad 07-29-2004, 07:29 PM Smart move! Change the cheaper part first and if that doesn't work go to the next step. If the fan speed went gradually then the resistor is a good bet. The fan only needs replaced if the motor is making noise. As for the ignition switch if the resistor doesn't work go to plan B. Automotive Network, Inc., Copyright ©2012
