I'm having an unusual amount of trouble trying to find the ALDL connector on my 1992 Rodeo. I have owned other cars with that type of OBD I connection and the location was always obvious.
The Haynes manual I bought says it is "on the drivers side, under the instrument cluster to the left of the center console" but I can't see it (even after I removed the kick pannel).
Do I have to remove the dash to get to it???
I don't seem to be the only one with this problem PLEASE HELP!!
white 3 terminal connector wrapped in clear plastic unless someone has already removed it by the way do you have a scanner TECH 1 if not look for the two wires with spades on them one female and one mmale when you find them pulg them together then turn on your ignition codes will flash out first you will see 12-12-12 then your trouble codes will be flashed
