i dont understand why
lalojamesliz
07-27-2004, 02:14 PM
ok my 98 4 cyl. auto camry le (98,000) gets around 20 miles to the TANK! some city driving and some freeway but when its only freeway my gas milage is fine i dont get it i use chevron reg. gas and i use the chevron fuel injector cleaner about every 1500 miles (it says i could do it every 1000) i have ngk laser platinum plugs and change them around every 10-15,000 miles (ngk 3452 $11.71 each) i have a k&n and clean it around every time it looks dirty i change my spark plug wires often (15,000) i also change my fuel filter every 15,000. the upstream o2 sensor(bosch O.E.) has around 15,000 miles and the down stream (bosch O.E.) has around 25,000 miles i also change my oil every 3-3500 miles (mobil 1) and my air pressure is right (36-40 psi recomended by kumo manuf.) my rims and tires size are 205*40*17 AND THIS IS WHEN I DRIVE LIKE A GRANDMA!!!!!!!!! i live in bakersfield and there is not that many stop lights..... i dont know i guess my camry likes to f****** swallow gas
Brian R.
07-27-2004, 03:02 PM
My best guess is that someone is stealing the gas from your tank with a siphon. Put a locking gas cap on it.
calvic
07-27-2004, 04:02 PM
Yea, I agree, Check out your neighbors 1st. next check out your fuel tank to see if it has a hole in it. 3rd sell me the car for $200 cause
you can't afford to drive this car if its only getting 20 miles per tank!!
:werd:
JJ
lalojamesliz
07-28-2004, 02:50 AM
:werd:
JJ
i wont take any less than $249.99 +tx :)
kman10587
07-28-2004, 02:52 AM
You live in Bakersfield huh? I'm moving there in three weeks (with my 96 Camry V6 LE). :)
lalojamesliz
07-28-2004, 02:55 AM
make sure you bring lots of sun screen, monday was a nice fresh 103 degrees
Brian R.
07-28-2004, 08:32 AM
And bring lots of gas.
calvic
07-28-2004, 04:48 PM
I live in Bakersfield too. Let me know when you get here, I can hook
you up with some inexpensive gas. You supply the container!
JJ :lol2:
Bossman
07-30-2004, 05:24 AM
Have your gas gauge checked for accuracy. Maybe the sending unit is shot. Happens!
Brian R.
07-30-2004, 10:22 AM
Buy the locking gas cap first. The gas gauge sending unit should be a problem both city and highway. It is less likely to be the problem.
gelcol
07-30-2004, 11:43 AM
gee!!!!! sounds like my favorite stripper girl she sippon my wallet after she did the 5 lap dance!!!
