Transmission flush query....
byubrian
07-26-2004, 11:37 PM
Just bought a 99 Rodeo w/ V6, 3.2L...
How can I tell if I need a tranny flush?
Should the flush be done by an Iauzu dealer or is an independent mechanic ok? This tranny is a bit different than what I am use to seeing.
Thanks
amigo-2k
07-27-2004, 12:26 AM
If you have over 80k on it,I would suggest that you take it to the dealer and have the tranny pan dropped and filter replaced. This will only replace about 3.5qts of the 9 or so qts in the system. Then next year have it flushed.
Otherwise, it is up to u if you want to spend a couple more bucks for the isuzu dealer to flush your tranny for you.
-Ryan
byubrian
07-27-2004, 01:05 AM
-Ryan
thanks, amigo-2k.
my rodeo has 47k. my concern re the tranny was that it seems a bit different than the standard tranny i am use to seeing (dipstick, etc.) and so i wasn't sure whether a tranny flush for a RODEO was so "specialized" that it should only be done by an ISUZU dealer. should the average indy mechanic have no problem doing a flush for a ROEDO?
who does your tranny flush? how often? how often should tranny filter be replaced?
thanks,
brian
JLMAres
07-27-2004, 01:36 AM
The tranny flush on the Rodeo cant be done by your run of the mill mechanic. It takes some specialized equipment to do as this is supposed to be a "sealed" transmission.
amigo-2k
07-27-2004, 09:44 AM
Yup, anyone with a tranny flush machine can do it. All they do is pull of one of the hoses that goes to the radiator and then flush it from there.
I flush mine every 25-30k (once every 2 yrs). I'm planning on having the filter replaced at about 75-80K (if you read my FAQ link below at the bottom of the page, there is a guy who had yearly flushes done and then he replaced the filter at 80k and he said there was an alumin paste in the filter).
-Ryan
