anti lock brake, brake, traction control light and service vehicle soon lights all on
Google
Web AF
aivideo
07-25-2004, 10:02 PM
anti lock brake, brake, traction control light and service vehicle soon lights all on. When I start the engine the lights come on as normal and then go out. Within 1 to two minutes all four of these lights come on. Had the barke system checked noting unusual. No codes int he computer. Disconnected the - cable from the battery and hooked it back up no change. Some of the fuses were loose in the passenger compartment I pushed them all in and tried the reset as well. What can I do next?
khodayeMashin
08-08-2004, 02:52 PM
I have the same problem and it's been going on for a while !!!
Any clues??!!
aivideo
08-08-2004, 05:48 PM
no clue I am looking for help
crazyduetoiowa
09-06-2004, 11:49 AM
my friend has a 98 regal, he had the same problem, he said it was the battery. He replaced it and now its fine
richtazz
09-09-2004, 04:22 PM
it's either a voltage problem (bad alternator, bad battery, bad ground, dirty connections, etc...), or you have a bad hub bearing or wheel speed sensor. The wheel speed sensors are part of the hub bearings, and that's what I would bet is your problem
Google
Web AF
