keyless entry lost remotegwreed 07-25-2004, 05:00 PM Recently lost remote to keyless entry for 98 crv. Can buy used one on e-bay for 15.00 compared to 100+ from dealer. Can used ones be reprogramed for my crv ? Thks gunnmen01 07-25-2004, 08:55 PM yes they can, as long as they are crv remotes,but its kinda hard to explain how.... buy them and take then into the dealer and let them explain how to program then... gunnmen01 lorunner 08-28-2004, 02:16 PM here is the programming steps 1997–04 CR-V LX with dealer-installed keyless entry system 1998–04 CR-V EX with factory-installed keyless entry system 2000–01 CR-V SE with factory-installed keyless entry system 2000–04 S2000 with factory-installed keyless entry system 2002–04 CR-V with dealer-installed security system Programming the Transmitter NOTES: • The system accepts up to three transmitters. The transmitter codes are stored in a stacking-type memory. If a fourth transmitter code is programmed, the code for the first transmitter is erased. • Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all of the transmitters once you are in the programming mode. • You must complete each step within 4 seconds of the previous step to keep the system from exiting the programming mode. Program the transmitters within 10 seconds. 1. Turn the ignition switch to ON (II). 2. Press the “Lock” or “Unlock” button on one of the transmitters. (An unprogrammed transmitter can be used for this step.) 3. Turn the ignition switch to LOCK (0). 4. Repeat steps 1, 2, and 3 two more times using the same transmitter used in step 2. 5. Turn the ignition switch to ON (II). 6. Press the “Lock” or “Unlock” button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode. 7. Within 10 seconds, press the “Lock” or “Unlock” button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter’s code. 8. Turn the ignition switch to LOCK (0) to exit the programming mode. Automotive Network, Inc., Copyright ©2012
