engine specs/data 4.3l V6- where to find?evol s10 07-24-2004, 05:26 AM is there someplace online that has specs and performance data (torque band, power band, etc,)? specifically for '94 s10 pickup vin Z. thanx for any help/ direction. smokey041369 07-24-2004, 08:02 AM 94 s-10 z code=4.3L tbi net horse power=165@4000 net torque ft lbs=235@2400 compression ratio=9.5:1 oil pressure=18@2000 evol s10 07-25-2004, 06:46 AM thank you for the reply. where did you get this info from? 94 s-10 z code=4.3L tbi net horse power=165@4000 net torque ft lbs=235@2400 compression ratio=9.5:1 oil pressure=18@2000 smokey041369 07-25-2004, 11:36 AM i have a book that covers 72-93 and some of 94 is the same as 93 evol s10 07-26-2004, 12:14 AM what i'm really looking for are the hp vs. rpm,torque vs.rpm graphs, and redline rpm. i've installed a tach, but do not know what are the optimal shift points are; or at what piont could i damage the vortec engine. if i'm barking up the wrong tree with this please tell me. thanx in advance for the info/help smokey041369 07-26-2004, 12:45 PM tachs work differently so what you need to do is keep the radio off fans off and drive the truck watch you tach when the motor sounds like it is winding out shift and remember the rpms. as far as red line i wouldn't take it over 4000-4500max Automotive Network, Inc., Copyright ©2012
