07-22-2004, 08:02 PM
Isuzu random missfire plus os2 sensor bank one sensor one switched to lean
Hello,
I have a 98 isuzu rodeo and recently had a clucth and slave and master cylinder installed. The problem that I was having before I took it to have a clutch put in it was the peddle went to the floor. They told me they had to drop the transmission also. I sometimes get a os2 sensor bank one sensor one switched to lean code p1133 and other times no. Also I have gotten a p300 random missfire. They tried new plugs and new coils plus they replaced the intake manifold gasket still no luck. Any ideas would really help. The os2 sensor has also been replaced the front one on the passenger side. Also my car feels like it has no power and will sometimes idle rough. This never happened before I had the clutch put in. Oh also the did bypass the a/c compressor with a special belt because they said it was locking up. I told them to bypass it because I couldnt afford the compressor now. they said that they ran it until it was smoking. I took it to someone else. to replace the other parts still no luck yet. It ran like a champ. Thanks so much for your replys.
07-22-2004, 08:13 PM
Isuzu specs
Oh I meant to tell you the type of Isuzu Rodeo,
98 3.2 6 cylinder 4x4 manual trans
07-22-2004, 09:58 PM
Isuzu Guy
Re: Isuzu random missfire plus os2 sensor bank one sensor one switched to lean
I would say the intake manafold gasket, but you replaced that already.
Have you cleaned your EGR/EGR port?
How old is the battery?
Alt on the way out?
Isuzu will do strange things if the charging system is weak.
-Ryan
07-22-2004, 10:10 PM
Reply to Amigo-2k!.........
Hello and thanks for your reply your info helps alot of people. I did take the egr off and clean it and the port to. Maybe I didn;t clean the port well enough? I used throttle body cleaner. Also I did mention the people at the first shop did run the a/c compressor until it was causing problems with the belt they said it was smoking and also it was so noisy I had to take it back to them because the a/c pully was wobbling. do you think it could have cause damage to my alternator and that would make it send a o2sensor or missfire code?
Thanks!
07-22-2004, 10:11 PM
battery age..............
I meant to mention the battery is a year old at the most.
01-03-2005, 06:30 PM
I'm having the exact same problem now. Same error codes also. It's in the dealer now. They say it's the intake manifold gasket. This is the 3rd one in 76,500 miles It's a 98 rodeo 4x4. Jerry
01-03-2005, 10:43 PM
the intake manifold gaskets on these are trash
I have never checked on a/m intake gaskets for these maybe they are not going to be plastic maybe you could check it out and let us know
01-03-2005, 11:48 PM
Try to use a higher grade fuel and use ISO-HEET water remove in every full tank of gas. Every oil change put some fuel injector cleaner. We have encountered Check Engine Light problems when using a lowest fuel grade and most are emission related error code.
1999 Dodge Truck RAM 1500 1/2 ton 4WD V8 360 Z 5.9L SFI QUAD CAB Sport Ed
1999 HONDA TRUCK PASSPORT 4WD V6 03165 3.2L MFI
1997 MERCURY SABLE 6 Cylinders 182 U 3.0L SFI
1994 PONTIAC GRAND AM L4 138 3 2.3L MFI SOHC QUAD
1990 OLDSMOBILE CUTLASS V6 191 T 3.1L MFI
1981 MERCEDES BENZ 240D 4 Cylinders 02399 2.4L DIESEL
01-13-2005, 04:22 PM
$280 later i have my truck back. the gasket has been updated. don't have exact part number. i called isuzu customer service, raised hell, they opened me a case #. service manager is to meet with zone rep. he decides if i get reimbersed by isuzu corp. if i loose my argument there is always small claims court. i can't imagine loosing there. dealer seems to be on my side. they know i have a good argument. we'll see! jerry
01-27-2005, 09:57 AM
Yes, there is a new updated part number for the intake manifold gaskets. The lowers ar ethe ones that go bad and there are two of them.
When you replaced your intake manifold "gasket" did you really mean to say gaskets?
If not I'd venture a guess as that is the problem. Bank one is the passenger side and bank two is of course the drivers side.
Hope this helps,
Joe
01-31-2005, 05:20 PM
Hope this helps,
Joe
Joe, yes I did mean to say gaskets (both sides) They have been replaced three times now. They swear that the faces are flat clean and smooth, i.e. no warpage. We'll see , my battle is not over! Stamey
01-31-2005, 05:30 PM
Isuzu Guy
what brand of plugs do you have in it?
01-31-2005, 06:26 PM
Re: Re: Isuzu random missfire plus os2 sensor bank one sensor one switched to lean
Still has original plugs. They still look fine. I'm not sure what that has to do with blown intake manigold gaskets. Explain. Stamey
