2000 Dash squeak - HELP!-amigo-2k 07-21-2004, 10:20 PM I have a horrible dash squeak! It sounds like a mouse. I remembered this post: http://www.geocities.com/endre_rl/isuzufaq.htm#faq55 and I tighten the three dash bolts (the middle one was loose), then I took it for a spin, and there it was still there! So does anyone know where I can pick up washers that have oneside which is rubber? I think I will also, remove all the nuts and take it for a spin too. It is driving me nutz! -Ryan 95.5 Rodeo 07-22-2004, 12:54 PM I have a dash squeak on my 1995.5 Rodeo and found / tightened loose screws, Etc. I tracked it down to the passenger's side airbag. While driving, I place my hand on it and the noise stops. I'm sure your dash design is different but it may be worth a look. Good luck, Dale psychopuppy 08-19-2004, 04:16 PM Amigo - Did you ever get the squeak fixed? My '01 Rodeo just started sqeaking. The only way to describe the sound is that it's the same squeak you get when taking a new tv (one that's packed in styrofoam) out of the box. Seems to be coming from around the guages and ONLY on hot days. Doesn't squeak early in morning. amigo-2k 08-19-2004, 04:23 PM I wish! 1. I tighten down the dash bolts (3), so squeak turn into more of a rubbing sound. 2. The removed the center and left nut and took it for a drive. It was still there. 3. I tried to put grease around the same bolts, and i sprayed silicon lube on the bold, on the windshield (which ran down the windshield and behind the dash), still no luck. 4. I removed the 2 screws by the cluster, and had about half of the black trim off (start from the top of the cluster) before I stopped. I didn't want to snap the plastic. So Here I am. The Rubbing sound is okay, with the radio at low levels, The squeak was driving me batty! The styrofoam sound, is about right. -Ryan Automotive Network, Inc., Copyright ©2012
