Galant VR-4 infoJDMDrft 07-21-2004, 11:14 AM I just recently bought a galant vr-4 and got a really good deal on it. The reason is that the engine as well as the clutch are blown. Anyway, I am very new to the Mitsu line up and was wondering if I could get some info like a spec sheet on the engine and also if anyone knows how to locate a front clip for one of these because they are rare. Also, if there are any other engine options like an early evo engine if its easier to get TRI_DAI 07-21-2004, 09:08 PM Modification VR-4, produced from 1990 (october) GENERAL Body type Sedan Drive FULL 4WD Transmission Advanced 5 speed manual Displacement, cc 1997 Frame E-E39A-SNPF SPECIFICATION (SPECS) EXTERIOR Exterior dimensions (LxWxH), mm 4560 x 1695 x 1440 Interior dimensions (LxWxH), mm 1825 x 1410 x 1175 Wheel base, mm 2600 Treads (F/R), mm 1460 / 1450 Ground clearance, mm 165 Curb vehicle weight, kg 1410 Gross vehicle weight, kg Seating capacity, persons 5 Doors number 4 Min.turning radius, m 5.3 Fuel tank capacity, l 62 ENGINE Displacement, cc 1997 Engine model 4G63 ECI-MULTI (turbo intercooler) Max.power (Net), kw(PS)/rpm 240 ps (176.52 kw) / 6000 rpm Max.torque(Net), N*m(kg*m)/rpm 31.0 kg*m (304.01 N*m) / 3500 rpm Power density 5.88 Engine type Water cooling serial 4 cylinder DOHC16 valve IC turbo Engine information Fuel system ECI-MULTI (electrically controlled gasoline injection) Turbocharger Turbo with intercooler Fuel type Unleaded premium gasoline LEV system (Low emission vehicle) No Compression ratio 7.8 Bore, mm 85 Stroke, mm 88 Final gear ratio Fuel consumption at 10-15 modes, l/100km 11.3 Fuel consumption at 60 km/h, l/100km CHASSIS / TRANSMISSION Power steering Yes Tires size, front 195/60R15 86h Tires size rear 195/60R15 86h Braking system, front Ventilated disk Braking system, rear Disk Suspension system, front McPherson strut type Suspension system, rear Double wishbone type Check /www.flashoptions.com/ for engine below, It should run you about 2500 shiped Mitsubishi Galant VR4 4G63 (RS) *Limited Edition* Limited Edition 240bhp. Big Injector, Big Intercooler, Eci Multi Intake Manifold, Big Turbo. TD05 (same like Evolution) JDMDrft 07-22-2004, 07:46 PM thanx, do you know where I could get a front clip? perhaps TRI_DAI 07-22-2004, 09:49 PM Check /www.flashoptions.com/ for engine below, It should run you about USD 2500 shipped Mitsubishi Galant VR4 4G63 (RS) *Limited Edition* Limited Edition 240bhp. Big Injector, Big Intercooler, Eci Multi Intake Manifold, Big Turbo. TD05 (same like Evolution) Automotive Network, Inc., Copyright ©2012
