Wheel spacers96Integra 01-30-2002, 10:49 PM I have been thinking about machining myself a custom pair of wheel spacers to prop my wheels about an inch or so outward, to emphasize my white rims a little, and to give the car an overall wider stance (w/o overdoing it). I am wondering, if I space my wheels a little under the fenderwell, and hit a good bump, do you think my tire might rub the fender? 96 Integra with 16" rims, and lowered 1.25" (If this helps:confused:) :finger: BURN BABY BURN:bandit: texan 01-31-2002, 12:53 AM What's the offset of the rims you are running now? Someguy 01-31-2002, 01:39 AM An inch? That's not a very good for a couple reasons. How many turns of the lug nuts is that going to cost you? You'll also increase scrub radius a lot and do some interesting things to the steering geometry. I guess you could roll your felders a bit for clearence if needed, but I'm not sure how that would turn out looks wise. CivicSiRacer 01-31-2002, 08:35 AM Do you realize how much an inch is? One inch = 2.54cm = 25.4mm. If you have a 42mm offset wheel and 16x7" wheels you will definitely rub. You can buy 1mm increment wheel spacers like I had to do. Mine came in 2mm and 3mm and my wheels/tires don't rub. They usually say you want 5-6 full turns of your lug nuts for it to seat properly or risk shaking the lugs loose on a hard turn. drift 01-31-2002, 05:54 PM you'll destroy your wheel bearings with that little of an offset Prpared 02-23-2002, 10:04 PM I don't recommend it. Neither would Honda. They would've done it first if it was the right thing to do. No?:D Automotive Network, Inc., Copyright ©2012
